Sponsored by BimmerWorld
Old 05-03-2011, 05:30 PM   #1
Kreeess
My Ride: 99' 328i
H&R cup kit with passengers?
Hey guys I'm really considering trying the cup kit set but I'm torn between getting the "touring" version or the "sport" version, I say that cause this will be on my DD and I do like to carry passengers in my car, wanted to know any feedbacks about having full cabin while on the cup kits, any rub, bottom out? Anything helps thanks!
Kreeess is offline   Reply With Quote
Old 05-05-2011, 10:08 AM   #2
Kreeess
My Ride: 99' 328i
Bump anyone?
Old 05-05-2011, 12:55 PM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I can't directly answer your question based on the fact I've never owned the Sport or Touring Cup kit.
I can tell you that when I endlessly researched suspension systems for my Bimmer, I came across quite a few people that had strut/shock failures with the H&R Sport Cup kit. Then I learned that H&R only warranties there strut/shocks for 1 year. So after 1 year, your outta luck.
Forum sponsor Turner Motorsport carries both the H&R Sport & touring combo, & the Bilstein and H&R Sport/race set. I went with the Bilstein and H&R race setup, I've been very happy with this suspension. The Bilstein and H&R combo come with a Lifetime warranty, so no worries if you ever experience a problem.
For your application I'd recommend the Bilstein/H&R Sport suspension system, as to any bottoming out with a full load, you should call Turner & H&R directly. I cant see that it would, based on the fact that your not slammed to the ground on any of these suspensions.
Turner Motorsport
H&R Sport/Touring $742.85
Bilstein / H&R Sport $819 http://www.turnermotorsport.com/p-36...uspension.aspx
Cost effective RSM $39 http://www.turnermotorsport.com/p-34...unts-pair.aspx
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-05-2011, 01:03 PM   #4
Snik
Snik's Avatar
My Ride: IR M3 Vert.
my car had the sport cup kit, with damn near 100k miles on it.
RE RSMs, never had a failure, even when the shock blew out.
never had an issue with passengers either, even with my fiberglass enclosure in the trunk adding another permanent 150+ lbs.
Do you ride a sportbike?
Old 05-05-2011, 01:10 PM   #5
Snik
Snik's Avatar
come to think of it, yeah it has over 100k mile son it. about to switch to eibach coilovers when i get home, but the fronts are still on, and i only changed the rear cause the shocks were blown and wanted a lower sitting spring. so now it has Bilstein sports + Tien s tech spring in back, and that also rides well, better id say as the spring is softer.
Old 05-05-2011, 01:40 PM   #6
Rob43
Rob43's Avatar
Hey snik,
About how many miles did your H&R Cup kit rear shocks have on them before they blew out ?
Old 05-05-2011, 01:53 PM   #7
Snik
Snik's Avatar
mmm, id estimate about 80k+ or so.
bought the car used and added about 60k to the suspension myself, before changing them. Think the PO put it on after the warranty ran out.
Front struts arent done yet, but they def dont ride like they used to.
Old 05-05-2011, 02:55 PM   #8
Kreeess
My Ride: 99' 328i
Cool thanks for the response guys, 80k isnt too bad I mean for what u pay for it I think 80k on rear struts pretty much paid for itself
And I'll def look in to h&r race spring with blistiens setup from turner for lifetime warranty for a few $$ more
Old 05-05-2011, 03:22 PM   #9
Rob43
Rob43's Avatar
Cool thanks for the response guys........
I'd still be thinking Sport, not race, for your application.
Good luck.
Old 05-05-2011, 06:43 PM   #10
Kreeess
My Ride: 99' 328i
Rob what's the drop difference between the sport and the race springs ? I thought race springs would have a higher compression rate or am I wrong
Old 05-05-2011, 07:20 PM   #11
Aaron90
My Ride: 328i
sport cupkit (race springs) I have it on my 328i
Aaron90 is offline   Reply With Quote
Old 05-06-2011, 12:32 AM   #12
Rob43
Rob43's Avatar
Turner Motorsport
E46 3-series Bilstein/H&R Sport Suspension
Part #: E46SPORTSUSP $819.00
E46 standard suspension F: -1.4" R: -.75"
E46 sport suspension F: -.75" R: -.25"
H&R Race
Race Spring E46 w/o sport suspension F: -2.0" R: -1.4" PN#29484
Race Spring E46 w/ sport suspension F: -1.1 R: -0.9" PN#50484-88
I'd still do the SPORT for your application.
Old 05-06-2011, 12:45 AM   #13
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
Im on a sport cup kit with spacers, no rear shock pads, and RE RSM's. I rub with anyone else in the car besides me but only because of the spacers. You can forget about 85% of speed bumps to, but don't get me wrong its definitely manageable.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 05-11-2011, 08:29 AM   #14
dkuchta
My Ride: 325cic
I just installed the sport kit (race springs) to my 325i Vert. Once finished loaded up the car with 4 people and took for a nice hard drive and not one problem. HOWEVER, I still do have the stock 16" wheels.. size should be same.. but that gave a lil cushion on the ride, which I was very surprised.. Not sure how is going to be with 17" or 18" wheels.. we'll see
dkuchta is offline   Reply With Quote
Old 05-11-2011, 03:07 PM   #15
Riverbmr3
My Ride: MB E350 & BMW 325i
have my H&R sport cup kit for three years, wheels on 18's staggered x 9.5 on a 245/35 rear. no rubbing, no problem with passengers.
Riverbmr3 is offline   Reply With Quote
Old 05-12-2011, 02:06 PM   #16
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We have all H&R cup kits available as low as $698.10...
Best,
Joe
Old 05-12-2011, 05:40 PM   #17
glenng
My Ride: '05 330ci ZHP
325i with a sport cup kit and staggered 19s. No rubbing even with passengers in the car. My car didnt have sports suspension so the kit dumped the look of my car quite a bit.
everything is hard, before it is easy
glenng is offline   Reply With Quote
