Old 05-19-2011, 10:18 PM   #1
jhaurimn
My Ride: 01' 330ci
Battery light, no power steering after OFH gasket change
any ideas?
i just took the fan back off to take a look at the belt, expecting that it slipped off, and it didnt...
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 05-19-2011, 10:43 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Hmm, make sure you put the alternator and the idler pulley back in properly and double check the belt pattern, most likely it's wrong.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 05-19-2011, 10:45 PM   #3
jhaurimn
My Ride: 01' 330ci
double checked belts, they are fine.
alternator is good as well
i can see the crankshaft pulley spinning but the belt isnt...would this mean tensioner needs to be replaced?
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 05-19-2011, 10:49 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
Does the tensioner have any bearing noise when you spin it by hand? does it move? or does it move extremely loose/freely
Old 05-19-2011, 10:51 PM   #5
jhaurimn
My Ride: 01' 330ci
it is loose. and i was gonna change it today when i did my ofhg, but ecstuning sent me a totally different part...
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 05-20-2011, 01:04 AM   #6
cvx5832
My Ride: 325Ci, 325Cic, C300
To be clear, the belts are routed as shown, correct?
cvx5832 is offline   Reply With Quote
Old 05-20-2011, 06:57 AM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
The belt isn't spinning? Then I hope you routed the belt incorrectly and it's just loose...I don't think a free spinning tensioner would stop the belt...but a seized bearing would. Check all pulleys.
And, make sure your alt is also plugged back in properly and that the cable is also hooked up, and that the bottom bolt is actually into the right spot, the right way.
Now, simplest explanation is improper routing (tensioners themselves do go bad, but I really don't recall one being so bad that the belt didn't move).
Be careful checking mounting of alt. I messed up on that and somehow bolted it on, but failed to get the lower bolt through the back 'ear' of alt. It still bolted in, and it stayed there 4 months, working, until my mech caught my mistake!
Facebook.com/DMAXstandup
Mangofy your E46!
