Sponsored by BimmerWorld
Old 05-04-2011, 07:02 PM   #1
Steven747
My Ride: 05 330ci
Are brake pad sensors necesary?
i am not interested in installing them because i can manually check if my pads are going down on life. will it throw a code by not having them? does the factory put it in ?
Old 05-04-2011, 07:21 PM   #2
stevenluczynski
My Ride: Is Steel Blue
you will have a yellow light on the dash telling you to change your pads.
but why not spend 10 and get one
stevenluczynski is offline   Reply With Quote
Old 05-04-2011, 08:16 PM   #3
Steven747
My Ride: 05 330ci
so if i dont have the sensors at all my cel will always be on?
Old 05-04-2011, 08:36 PM   #4
stevenluczynski
not you cel but a warning light yes.
Old 05-04-2011, 09:03 PM   #5
Steven747
My Ride: 05 330ci
i dont think i have a warning light n the dash besides the cel do i?
Old 05-04-2011, 09:10 PM   #6
stevenluczynski
You would see the break pad warning night
Old 05-04-2011, 09:12 PM   #7
Steven747
My Ride: 05 330ci
ohh ok so does bmw put sensors on when they do a warrantied brake job?
Old 05-04-2011, 09:16 PM   #8
stevenluczynski
Anytime that light goes on to reset it you must get a new sensor. So yes.
Old 05-04-2011, 09:17 PM   #9
joneperry
My Ride: e46 + S60 + Z
You are only going to have that round brake pad sensor light on http://www.bimmerwerkz.com/forum/att...-dashboard.jpg
all the time, why not just buy a sensor, its about 17 bucks for both, since you only need 2 (one for rear and one for front). It becomes illuminated due to the circuit being broken when the caliper closes when the brake pedal is applied and the sensor wire is cut due to the thickness being low. If you somehow just cut the wire and install close the loop before it gets to the caliper, I dont think it would need to be changed. Its a safety feature and if you sold the car to someone like that then
joneperry is offline   Reply With Quote
Old 05-04-2011, 09:40 PM   #10
Steven747
My Ride: 05 330ci
cool yeah i know what your saying but the way i see it is that i visually inspect my pads once a month and like currently i just purchased a brake package from bimmerworld and i believe i still have 30 to 40 percent left on the pads so ill never get to minimums like that
thanks every1 question answered
Old 05-07-2011, 06:03 PM   #11
Steven747
My Ride: 05 330ci
wwait 1 more questione if i change out my pads before it triggers the brake wear sensor i can use it again correct and it wont go pbad until the thickness of a set of pads goes below minimuns.. so reletively speaking you could change out 10 pairs of pads at 30% and still have the same senosrs?
i promise last question
Old 05-07-2011, 07:08 PM   #12
stevenluczynski
Yup! but why not buy the 5 dollar sensor and use your pads completely?
http://www.ecstuning.com/BMW-E46-325...448/:thumbsup:
Old 05-07-2011, 07:15 PM   #13
Steven747
My Ride: 05 330ci
just for this time because my rotors are dust and i was under warranty and they replaced the pads but not rotors so im just going to jump into some stoptech pads which the stock paads have a little more than 35% left so im just going to reuse the sensors...? wouldent that just make sense? and do you think i could sell some used pads like that for like 30 bucks lol thanks alot man you really cleared up some questiones about the sensors
