Sponsored by BimmerWorld
Old 04-06-2014, 11:05 AM   #1
Alekm
My Ride: 323 E46 1999 AT 170k
Caliper pressure when putting new pads
I noticed on few occasions recently that the rear driver side wheel was getting too hot. There was some slight rubber burn smell.
So while doing a brake job to replace rotors and pads, when trying to press the caliper, it would not budge. I even broke my C clamp while trying . So I need a new caliper, ordered one from bavauto, and while doing all this, given the age of the car I decided to replace the brake lines as well. It was odd that the pads on the other rear side were so unevenly worn. Maybe 1/3 compared to the side with the stuck caliper which was almost all gone.
Now, my question is how tough should the caliper resistance be when trying to press them. The front two were bit tough but was able to press them completely to make space for the new pads. The other rear caliper was very easy to press. I am wondering if there is a way to diagnose when the calipers may start to fail and if it is worth to replace them all.
Thanks,
Alekm is offline   Reply With Quote
Old 04-06-2014, 11:09 AM   #2
shovelit
My Ride: 03 325xi and 04 330x
Steady even pressure should do it. I always replace them in pairs.
shovelit is offline   Reply With Quote
Old 04-06-2014, 11:55 AM   #3
ChuckyVee
My Ride: 2000 323i, '99 328is
Thanks,
You took off the cap from the fluid resvervoir when pressing in the caliper piston correct?
First Bimmer..."Miss December"...2000 323i, purchased Dec. 2013 w/82K on the clock. PM thus far...pads/rotors, belts/pulleys, complete CS overhaul, FCABs, plugs, autotranny/differential service, fuel pump, filter, and relay. Full front end refresh with LCAs and bushings, struts and mounts, inner/outer tie rods, sway bar endlinks and bushings.
ChuckyVee is offline   Reply With Quote
Old 04-06-2014, 12:07 PM   #4
Alekm
ooops, no I did not. Maybe that explains the harder than expected pressure that I was getting. Don't remember having that much hard time when I did the brakes 6 years ago.
Would that cause any problems to the remaining calipers or abs system?
Old 04-06-2014, 05:41 PM   #5
RayPooley
My Ride: 320i SE Coupe
Your brake fluid system is a sealed system to all intents and purposes although its not air tight. Leaving the res cap on would certainly cause problems when trying to push the piston back into the housing. The other thing, of course, is that the pressure you applied using the G clamp would be borne by the seals on the other calipers and the master cylinder so there is a possibility of damage to seals under such circumstances, I suppose, depending on how old and worn they are. Check you fluid level daily after you have completed the job for the first couple of weeks. Caliper pistons can rust up if the rubber boots split. Probably why they were problematic.
Old 04-06-2014, 05:44 PM   #6
racin366
My Ride: 04 325ci
For the rears on most cars the caliper needs to be rotated to compress, not pushed in due to the e brake. I am not sure if this applies to BMW, IIRC they may use a different type of e brake setup that makes this info useless.
racin366 is offline   Reply With Quote
Old 04-06-2014, 06:04 PM   #7
RayPooley
Why would you need to rotate the caliper to press the piston in? Doesn't make sense. The hand brake is a cable operated drum brake. Nothing to do with the caliper or the hydraulic system. Totally independent of it in fact.
Old 04-06-2014, 06:30 PM   #8
Alekm
That makes sense. The system is 15 years old, so hopefully there is some leakage. I will be checking in the fluid levels once the job is completed.
Old 04-06-2014, 07:25 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
It's a PARKING BRAKE, and it's completely separate from the service brakes.
Old 04-06-2014, 07:29 PM   #10
racin366
My Ride: 04 325ci
That is what I thought, but on many cars the e brake is just a cable that tightens the rear calipers, so to compress them when changing pads you have to turn them like a screw, squeezing won't work and may damage the caliper.
Sounds like OP may have a bad caliper.
Old 04-06-2014, 07:30 PM   #11
tkrotchko
My Ride: 2002 330i
There's a couple manufacturers who do this. Honda is one. One of the swedish brands as well.
But BMW does NOT require you to rotate the rear piston.
tkrotchko is offline   Reply With Quote
