Sponsored by BimmerWorld
Old 05-05-2011, 02:24 PM   #1
Steven747
My Ride: 05 330ci
Dinan bushings?
http://www.dinancars.com/shop/R280-0...it.aspx#page=4
can someone elaborate?
Old 05-05-2011, 02:28 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
On what? It's a very expensive spherical bearing RTAB replacement suitable for race use only.
Old 05-05-2011, 02:52 PM   #3
Steven747
My Ride: 05 330ci
bearing ? does that mean i can swap out my meyle hd's and put these in or where do the dinans sit exactly?
Old 05-05-2011, 03:29 PM   #4
TxZHP04
Yes, the Dinan part would be a direct replacement for your Meyle HD RTABs. I would highly advise against running these in a street driven car. Stick with OE/OEM bushings combined with limiters.
Old 05-05-2011, 04:27 PM   #5
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Plus, you can buy the Ground Control version for $299...
Old 05-05-2011, 04:37 PM   #6
FTWeisse
My Ride: has no hip-hop rimz
800 bucks? I like Dinan and all, but you gotta be shittin' me...
+1 on GC if you're going to go spherical. But on a street car? C'mon...
Old 05-05-2011, 04:54 PM   #7
TxZHP04
I can understand the quest for the ultimate in parts longevity but many people fail to understand the consequences of alternative designs whether it be a bearing in place of a bushing or materials like delrin and poly instead of rubber. And many times, these parts won't necessarily last any longer than (or even as long as) the stock rubber part.
Old 05-05-2011, 06:19 PM   #8
Steven747
My Ride: 05 330ci
ok thanks for all the info i just didnt know too much about it but now i do
Old 05-05-2011, 08:27 PM   #9
aggieE46
Keep it clean
aggieE46's Avatar
Searching for G.I. Joe image...
Old 05-05-2011, 11:41 PM   #10
Steven747
My Ride: 05 330ci
haha what? and aggie are you on powerflex or meyles?
Old 05-06-2011, 05:25 AM   #11
aggieE46
Keep it clean
aggieE46's Avatar
Knowing is half the battle!
M3 RTABs with Vorshlag limiters.
Old 05-08-2011, 11:24 PM   #12
Steven747
My Ride: 05 330ci
all 4 corners?
Old 05-09-2011, 07:18 AM   #13
TxZHP04
all 4 corners?
What? There are only 2 RTABs.
I think Brady runs the same setup I do: OE M3 RTABs with the Vorshlag limiters in back and Meyle HD CABs up front.
Old 05-09-2011, 08:19 PM   #14
Steven747
My Ride: 05 330ci
theres 2 bushings in the back and 2 in the front
Old 05-09-2011, 08:25 PM   #15
TxZHP04
But there are only 2 RTABs. The 2 you are referring to in the front aren't RTABs (rear trailing arm bushings, which by definition are in the rear). Those bushings are control arm bushings and are not used with limiters. RTABs and CABs are different bushings with different designs for handling slightly different jobs.
Old 05-09-2011, 08:58 PM   #16
Steven747
My Ride: 05 330ci
yes thank you for the explanation siri did just say 4 corners because there are 4 different main suspension bushings to replace.. no where i said 4 rtab...
Old 05-09-2011, 09:10 PM   #17
TxZHP04
This whole thread has been about RTABs so far. Seemed as if you were asking Brady if he used the same bushings up front as in the back. Hard to tell when you're going OT when you don't use complete sentences.
