Old 08-15-2010, 07:15 PM   #1
parody
My Ride: 2004 e46 330d
E36 330i SMG/SSG Reservoir location
Hi!
As per title - where is it?! Want to check the level... its a UK spec car. Ive been scouring the net for hours and can find plenty of "check the level" but no indication of where to check it! I have a reservoir at the front right (as you look at it) with a star shaped cap saying "ATF only" on it, but from what I have seen the reservoir is around the right middle of the engine near the inlet manifold, but I dont have one there.
Any ideas?
parody is offline   Reply With Quote
Old 08-15-2010, 07:42 PM   #2
Messe46
My Ride: 325xi ZSP - ONRLS
Send a message via AIM to Messe46
As you face the engine (from above), look to the 'top-right'. I believe that's where they put the reservoir on the m3 with smg, should be similar to any other model with smg.
-Mike
Im sorry, but having an Aston Martin DB9 on the drive and not driving it is a bit like having Keira Knightley in your bed and sleeping on the couch. If youve got even half a scrotum its not going to happen.
-Jeremy Clarkson
Messe46 is offline   Reply With Quote
Old 08-16-2010, 02:49 AM   #3
parody
thanks ill take a look. Any indictaors on it at all? Does it have a built in dip stick?
Old 08-16-2010, 03:57 PM   #4
parody
Hmmm, OK I still cant find it. Here is a pic of my engine bay, and another up the top right area. I cant see a reservoir hiding anywhere.
Name:	EngineBay [1024x768].JPG
ID:	371836   Click image for larger version
Name:	EngineBay2 [1024x768].JPG
Old 08-17-2010, 05:00 AM   #5
parody
bump.
No one knows?
Old 08-17-2010, 09:01 AM   #6
Blocked Out
My Ride: Imola 330i M-Sport
I dont know, so I would guess and my guess is that there is no reservoir and the fluid is pumped directly into the SMG pump and there is no way to check the level just like there is no dipstick in the tranyy nor in the diff.
I could be wrong but I also could be right.
Original BMW Teile ///
IMG_1725
Old 08-17-2010, 12:54 PM   #7
B33MER
My Ride: 330i SMG M-Sport
You need to lift the car up ... It's on the left rear side of the gearbox ... You will see the SMG/SSG reservoir ... Get a flash light it'll be easier to check the fluid level with the light ... Hope that helps.
p/s: Pentosin CHF 11s is the recommended fluid ... tho there are (better?) alternatives if you want to be adventurous
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 05-10-2011, 01:40 AM   #8
Manza
My Ride: E46 330Ci SMG
Yeah, you need to go under the car and look at a small opening on the left side of the gearbox. There you will see a see-through container with a plastic cap (with a 17mm hex wrench size). This is the filler cap. The fluid level can be seen through the reservoir.
http://www.realoem.com/bmw/showparts...60&hg=23&fg=15
Manza is offline   Reply With Quote
Old 05-10-2011, 10:14 AM   #9
xavi330i
My Ride: 2004 330i smg
The ZF smg has the reservoir on the tranny.
xavi330i is offline   Reply With Quote
