#1 |
mixing oil brands?
How inadvisable is it to combine different brands of 5W-30 when filling up the oil?
#2 | |
Stay stock my friends!
You're allowed to add one of the approved LL-01 oils if needed to top off a fill of OE oil that's low...when OE oil isn't available. I'm sure the purists would say don't do it, and I haven't done it myself, but the real key isn't the weight as much as the LL-01. Oh, the purists like me would also say it's better to top off than run low. But I'd also say that if you've just got the low oil light on now, you could wait until tomorrow to get the same oil, but you should check your oil level when car has been sitting a long time to figure out how much to add. Don't turn it off, see it's at the bottom notch and add a qt. of oil. As you might end up a half a qt. high. Oil takes a while to settle. More than you wanted, right? LOL
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#3 |
Good info as usual dmax
- UUC Stg. 1 LTW Flywheel - UUC SSK + DSSR - UUC TM +TME - UUC Rear Adjustable Control Arms - UUC Swaybarbarians - AST Sportline II - - RE Underdrive Pullys - RE FCABs - BMW Performance Control Arms - Shark Injector - EMP High Flow Water Pump - TMS Adjustable Endlinks - K&N CAI - - M3 Motor Mounts - For Sale |
#4 |
I'm so glad I didn't say anything to offend you! Some of you Dons seem pretty touchy!
#5 |
I've done it from time to time with no issues...I keep the weight the same obviously.
#6 |
Lol. Yeah, I can see how that could be the case at times. I try to keep things mellow as I haven't found a way to put a horses head in somebodies bed via forums yet.
#7 |
Thanks for all the info! Follow up question: what's the difference between "fully synthetic" 5W-30 and "synthetic blend" 5W-30?
#8 | |
Failing that, get full synthetic 5/30 (non LL-01 if you have to) and just change your oil sooner rather than later. I'm pretty sure oe oil is full synthetic, but you can also check bmwna for that info...search for oil specifications or fluid specs. It's there.
#9 | |
BMW Long-life rating LL-01 Approved Synthetic Oils for the US Market: Castrol Syntec European Formula SAE 0W-30 Mobil 1 SAE 0W-40 Pennzoil Platinum European Formula Ultra SAE 5W-30 Valvoline SynPower SAE 5W-30
![]() 2003 325XI 5-speed ZSP ZPP |
#10 |
To clarify, what does LL-01 mean?
#11 |
My Ride: Ex 325CI owner
Synpower MST 5W30 meets spec (LL01), NOT the common Synpower 5W30.
#12 |
Banned
I've mixed different brands and weights before when topping off. As long as it's within specification and meets all standards it's fine. I use the same oil when I do an oil change.
#13 |
I just topped mine off a few hours ago with a different brand. So far my engine hasn't burst into flames.
number one Audi Fan
#14 |
I could be wrong, but I always interpreted it as 'Long Life circa 2001 spec." oil.
#15 |
It means many things but the important ones are that viscosity is around
12.0 cSt @ 100C, and that HTHS is a minimum of 3.5. Most XW30's don't meet this spec for example M1 5W30. |
#16 | |
#17 |
ALL oils are compatible with each other.
#18 |
Gn?
![]() On his deathbed: Either that wallpaper goes, or I do. - Oscar Wilde |
#19 |
I'll have to double check when I get home, but I don't recall the bottle referencing LL-01 or LL-anything on it. Is that a bad thing, or am I just not looking close enough?
#20 |
The wrong oil is better than no oil.....
2003 E39 M5 Lemans Blue: The most amazing car ever built
-------- 1999 E46 328i Bone stock 5-speed: Soon to be track rat 230K and still running strong |
