Old 10-15-2011, 02:40 PM   #21
trj
My Ride: 325Ci
Thanks for the black silicon tip.
Will head out to the hardware store in the evening and see if I can get the other light by tomorrow.
The board is secured for sure, with two screws.
But I am more concerned about the water leaks getting inside the lights because I cut on the outer perimeter of the edge(your picture shows the cut inside the inner perimeter).
May be the black silicon will help, I will put one layer of electrical tape over it anyway to prevent any leaks.
I am sure it will help people.
But one must have patience for this though.
cutting the lights, testing the LEDs one by one, and de-soldering the bad ones, resoldering and sealing takes takes steady hands and a lot of patience.
Old 10-17-2011, 01:43 AM   #22
trj
My Ride: 325Ci
The passenger side is also done today.
sealed with Black silicon, will write a DIY soon.
But what a pain to cut those lights.
Well, saved some bucks, so no complains.
Just hoping that the LEDs don't burn out again.
I don't want to cut them again, although I have so many LEDs for spare now.
Special Thanks to Intelone for the guidance.
Old 10-18-2011, 03:22 AM   #23
trj
My Ride: 325Ci
Thanks guys, I made a DIY on the same.
heres the link
http://forum.e46fanatics.com/showthr...2#post13711162
Old 10-20-2011, 02:56 PM   #24
kyparamedic
My Ride: 330i
I'm having a similar problem except mine are not burnt out, they just function intermittently. The driver's side turn signal works for a while then may not for several days. Brake lights are not affected. I've checked the connections as best I can and everything seems fine. Any idea what the problem could be? What options do I have? I hate to buy a new pair but don't know where I can buy just the driver's side. I originally bought them from Unique Euro Design but have not been able to contact them.
kyparamedic is offline   Reply With Quote
Old 10-20-2011, 05:18 PM   #25
Riverbmr3
My Ride: MB E350 & BMW 325i
my EE leds failed after two yrs, trashed it and went to R/C/R, no more
Riverbmr3 is offline   Reply With Quote
Old 10-20-2011, 06:01 PM   #26
trj
My Ride: 325Ci
@kyparamedic: may be an issue with the connection. There are a coupe of cables going from the top board to the bottom board. I would check those. Also E46 is infamous for tail light ground issue, so check the ground if its applicable with EE. I am not sure. I just bought this car so a lot to learn yet. But I would check the ground and the connections first.
@pinoybmr3: I was going that route too. I was talking to a fellow fanatic who was selling his R-C-Rs, but just thought to give this a try. Lets see how long it holds and if it does again, I have a ton of LEDs left over.
Old 11-02-2011, 01:31 PM   #27
kyparamedic
My Ride: 330i
[QUOTE=trj;13720965]@kyparamedic: may be an issue with the connection. There are a coupe of cables going from the top board to the bottom board. I would check those. Also E46 is infamous for tail light ground issue, so check the ground if its applicable with EE. I am not sure. I just bought this car so a lot to learn yet. But I would check the ground and the connections first.
I just went over everything again. I can't find any connection issues/loose wires. The brake light on that side works fine, it's just the taillight, which hasn't worked in a week. Could it be the resister box? There appear to be 2 for each side. I wonder where I could find a replacement to see if that's the cause?
Thanks.
Old 11-02-2011, 01:45 PM   #28
trj
My Ride: 325Ci
[QUOTE=kyparamedic;13759790]
Thanks.
I wonder if the boxes are sold separately, but try swapping the little boxes from the working side and see if the lights work. Also check the connections from the factory harness to those boxes. Did you check the connections with multimeter? Sometimes the connections seem fine but do check with the multimeter to make sure you are getting the flow.
Old 11-12-2011, 03:32 PM   #29
kyparamedic
My Ride: 330i
[QUOTE=trj;13759834]
Ok, I finally got around to swapping the boxes and that was the problem, although it's still a little weird. When I tried the small resistor box from the working side on the non-working side, it worked fine. There must be a problem in some of the wires that connect from the other box though as without the box connected, neither the brakelights nor turn signal work. With the faulty box connected, only the brakelight works.
Anyone know where I can get replacement resistor boxes? I've attached a pic.
Thanks!
Old 11-21-2011, 07:20 AM   #30
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
[QUOTE=kyparamedic;13792316]
Thanks!
http://forum.e46fanatics.com/showthr...&highlight=led
My post on how I was able to fix that box.
phamine is offline   Reply With Quote
Old 12-30-2011, 03:48 AM   #31
xlzx90
My Ride: E46 320d
Hello!
I have a problem with my tail lights. My left tail light has an error. I can see the normal light, but when I braking I can not see the braking lamp. Its working when the normal light is off, but it's very slightly! The right side is perfect! What can I do? Can you send me an othet motherboard, or what can be the problem?
Thank You,
Happy New Year!
George
xlzx90 is offline   Reply With Quote
Old 12-30-2011, 04:58 AM   #32
trj
My Ride: 325Ci
you are posting on every thread. I replied in the other one, don't want to type the whole thing again.
Old 10-21-2015, 02:08 PM   #33
mr_y82
My Ride: 01 325xi Sedan
Thanks!
I know this is ancient, but in case someone stumbles into it...
http://www.khoalty.com/bmw-e46-led-t...-resistor.html
My left turn signal stopped... I might try this first and then proceed if necessary...
Originally Posted by Dirty330i View Post
On the wiring harness where it connects to the car find the brown ground wire(on the car side of the harness) I believe it is pin #6 (top row has 4 pins and bottom has 3; the middle one on the bottom row is the ground. Cut that wire closest to harness then strip the end of the wire 1/4 inch. Then on the Eagle Eye harness the corresponding grounds(2) are the black wires that would match up to the cars brown ground. Again cut those close to the harness and strip the ends. From here I used a marrette to splice the three together then simply grounded off the low bolt holding the light assembly to the body.
This solved my issues hopefully it'll work for you too. I did this without taking them off my car although it probably woulve been easier with them removed just because of space. I'm on my phone so I can't do pics right now.
Cheers
H&R Sport Springs on Bilstein Struts; Valeo SMF, non-SA Clutch, CDV delete, and E60 Shifter w/ ZHP knob; Beisan System VANOS Seals...
Mtech-II Front Bumper (PO got bumped in parking lot!); Eagle Eye LED Tail Lights... Lots of PM!!!
mr_y82 is offline   Reply With Quote
eagle eye, led, problems, tail light
