Sponsored by BimmerWorld
Old 05-09-2011, 09:42 PM   #1
jkert323
My Ride: 1999 bmw 323i
Installed E46 sedan Eibach Pro system kit...few more pics
Just installed an eibach pro-system kit with damper shocks and pro kit springs. pain in the ass but way worth it. front had stock shocks and the rear shocks were replaced before i got car with kyb gr2. So i figured to make em all the same plus i think the look aint that bad. This kit has a great ride and no roll on corners. i ordered some Beyern mesh 5 in 18inch but cant make up my mind.
cell pics sorry
Edit.................its getting nice out ima take some clean pics..... a few more..
ID:	403028   Click image for larger version
jkert323 is offline   Reply With Quote
Old 05-09-2011, 09:55 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Great job, Looks good.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-11-2011, 11:34 AM   #3
jkert323
Thanks..... and nice car
Old 05-12-2011, 03:30 PM   #4
Lune
My Ride: E46 M54B25 Touring
Looking nice.
Would you please measure the distance from the center of the wheel to the fender both front and back?
BR
Michael
Lune is offline   Reply With Quote
Old 05-12-2011, 09:40 PM   #5
jkert323
I have 205/55/16 all the way around and they measured in the back from center of wheel 13 1/4 inches and the front at 13 3/8
Old 05-12-2011, 11:43 PM   #6
Lune
That perfekt - thanks.
Old 05-23-2011, 03:22 PM   #7
jkert323
323i pro system more pics
a few more pics of the ride...
Any opinions on a front bumper Csl or M3 rep?
ID:	404451   Click image for larger version
Old 05-23-2011, 03:30 PM   #8
M323i
My Ride: 1999 323i
Send a message via AIM to M323i
+1 on the ride, and I'm currently looking at new suspension as well...so im glad you posted this.
I had a CSL v1 and liked it, I have an m3 rep front that I haven't put on yet...I think im going to like the m3 rep better personally...
Mod List
1)18" CSL Reps
2)CSL rep bumper
Coming Soon
3)cold air intake
4)Projectors
5)New Suspension
6) Exhaust
7) New Brake kit
8)Sway Bar
Sign by Dealighted - Coupons & Discount Shopping
M323i is offline   Reply With Quote
Old 05-23-2011, 05:57 PM   #9
nwb0010
My Ride: 2004 325i
Oh man I cant wait till I get my Pro Kit on my 04 325. Any tips on swapping these bad boys out?
Also did you like the KYB's?
nwb0010 is offline   Reply With Quote
Old 05-23-2011, 06:27 PM   #10
jkert323
A spring compressor is a must for the front. I used it on removing old and installing new setup plus a second pair of hands helps too. I took off the brakes to get extra space and that helped out. They were just 2 bolts each. replace your strut tower mounts in front and rear for me all 4 cost about $110. In the Pro system it comes with the front bump stops -not rear- but my rear were still good. also rear spring seats if worn upper and lower. took about 2hrs for each front side about hour for complete rear swap with a brake or 2. Do a complete torque of bolts. In my kit the new front tower bolts were same thread but a socket size bigger so there for it socket would not fit to tighten. I used old bolts till i could get new ones..if u run into this email me or if u want pics to see what bolt.
In my opinion the Kyb's were a lil soft but that could have been age. I have a set on my vr6 corrado with FK springs and its a solid ride nice corners
anything else just ask.
