Sponsored by The Tire Rack
Old 05-10-2011, 09:14 PM   #1
E34Addict
My Ride: E34 540I/6
Inside wall damage, questions
I had a pretty new tire that popped off the wheel when doing agressive turn and I had to limp around 1-2 blocks. There are no holes in it but a local tire shop I went to opened it up and told me I need a new tire due to inside damage.
The debris from damage was minimal (shavings) and side wall still looks okay from inside a bit worn where rim was going over it.
I'm using another tire now but just want to know, if there is a case such as this can tire be reused safely? I'm second guessing opinion of the street shop because they are in business of selling services/tires and I don't want to throw this one out and find out it could be used fine.
///////////////////////////////////////////// E34 Addicts
E34Addict is offline   Reply With Quote
Old 05-10-2011, 11:40 PM   #2
WALKD U
My Ride: Just Fast!
On any low pro cant limp on the tire with no air. IT WILL RUIN THE TIRE!
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 05-10-2011, 11:41 PM   #3
E34Addict
My Ride: E34 540I/6
I was on major intersection and simply made 2 blocks to pull over and change it.
Old 05-10-2011, 11:58 PM   #4
2003 325i
My Ride: '03 Orient Blue 325i
Sidewall damage = new tire, everytime.
Take it from someone who's changed hundreds if not thousands of tires...
Old 05-11-2011, 12:42 AM   #5
WALKD U
My Ride: Just Fast!
2 Blocks will ruin tire...
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 05-11-2011, 12:47 AM   #6
w0w
My Ride: '02 M3 Vert
inside damage probably sounds like the sidewall gave out or the bead is messed up. get it checked out but sounds like youre out of luck
daron
w0w is offline   Reply With Quote
Old 05-11-2011, 12:34 PM   #7
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Definitely sounds like sidewall damage, which renders the tire unusable.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 05-11-2011, 01:17 PM   #8
E34Addict
My Ride: E34 540I/6
Gotcha, will throw it out. Thanks guys.
Old 05-11-2011, 02:06 PM   #9
Penguin Koolaid
Banned
My Ride: Inline Six
That's the right call. There are some things you absolutely do not want to risk... and running on a damaged tire is one of them.
Penguin Koolaid is offline   Reply With Quote
Old 05-14-2011, 11:36 AM   #10
Xcelratr
My Ride: 04 330Ci ZHP
Eleven years in the performance/racing tire business and I never once heard of a properly inflated tire "popping off" the wheel without some kind of lateral impact. Did this aggressive turn involve an aggressive impact with an aggressive curb?
If one of my customers brought me a tire that had "popped off" the wheel, that tire wouldn't be going back on a wheel in my shop, no matter how the sidewall looked.
We will not tolerate intolerance.
Xcelratr is offline   Reply With Quote
