Sponsored by BimmerWorld
Old 05-11-2011, 12:35 PM   #1
Dr. Anthony
My Ride: E92 M3, E46m3cab,x5d
help choosing shocks for 2002 325xit
Hi guys. I'm looking to replace the rear shocks on my wife's 2002 325xit wagon.
I may just pick up a complete front/rear set.
I'm trying to keep costs down.
Turner has Bilstein shocks for $449.
OR, I Could just buy rear stock replacements from tischer.
Its a stock wagon. I have a set of 18s on there now, but may swap them with 16s.
She's looking for more of a smoother ride. which do you recommend?
Bilstein's HD, Sport, or stock?
which one of those would give a smoother ride?
http://www.turnermotorsport.com/p-10...30xiset-4.aspx
http://www.turnermotorsport.com/p-14...0xi-set-4.aspx
Thanks!
Dr. Anthony is offline   Reply With Quote
Old 05-11-2011, 12:52 PM   #2
SamDoe1
My Ride: 4cyl of fury
Sorry to start off with this but if you look at the first page in the XI forum, there are at least 5 threads that address your issue.
Secondly, Bilstein shocks will be much more firm than the OEM ones. If you are going for softer/smoother, OEM is the only way to go.
Old 05-11-2011, 12:54 PM   #3
Dr. Anthony
hi. thanks for the input. I unfortunately saw the thread AFTER i posted this thread
i'll continue reading it.
So, a stock shock would be "softer" than any of the aftermarket ones?
Old 05-11-2011, 12:59 PM   #4
SamDoe1
Yup, stock is the softest of the group. Anything else is going to be more firm. Make sure your springs are in good shape too though, if your shocks are blown there's a good chance your springs are broken too.
Old 05-11-2011, 01:02 PM   #5
Dr. Anthony
The rear springs were replaced about 2 months ago. At the time, the shocks seemed OK but i'm sure with all the pot holes out there now, it didn't take much for them to finally die.
Old 05-11-2011, 02:45 PM   #6
DJ Reminisce
My Ride: Knows Dubstep SUCKS
Smooth ride:
1) Progressive spring
2) Koni FSD shocks/struts (not sure if they have an application for the xi wagon)
Dinan CAI_Stage II_3.46 Dif
OEM CF Strut Bar_Eibach Sportline_GC Konis
OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters
Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems
500W_RE Audio_Hertz Components
DJ Reminisce is offline   Reply With Quote
Old 05-11-2011, 03:24 PM   #7
Arsevader
My Ride: '90 325i, '02 325it
Koni Orange. Str.t.
This is what I had on my touring, was a good ride. Firmer than stock but not as firm as Bilstein Sports.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 05-11-2011, 03:50 PM   #8
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by DJ Reminisce View Post
Smooth ride.......
My thoughts exactly.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-12-2011, 02:13 PM   #9
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We have a section of E46 325Xi shocks available below...
Best,
Joe
