Sponsored by BimmerWorld
Old 05-11-2011, 06:00 PM   #1
TrickTizzle
My Ride: 325i
Quick question about camber plates/coil over
Hey guys, quick question.
I just ordered my coilovers, and I'm wondering if I need camber plates?
I know OEM doesnt have much adjustability, so if it would be a good idea to install them while I'm at it. I do want some camber upfront so I can go low. Not slammed though.
Also, if I do get camber plates, I hope it wont interfere with my strut brace?
Old 05-11-2011, 06:17 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
What coilovers did you get ?
You might not need them, when you install a lowering suspension you usually end up with more negative camber. My Bilstein and H&R race springs gave me
(F)-2.1, (R)-1.9 camber....if I remember correctly.
Your strut brace may need modification.
Good luck
SUMMIT POINT WV 1:24:229 SCCA
Old 05-11-2011, 07:20 PM   #3
TrickTizzle
My Ride: 325i
Good luck
Thanks man! The only thing I want is some noticeable camber in the front. But -2.0 sounds pretty noticeable...
Thanks for the help bud.
Old 05-12-2011, 02:03 PM   #4
ECSTuning
ECSTuning's Avatar
My Ride: BMW
If you do determine you need them we have UUCs available below...
The experts at UUC produce high quality parts for BMW enthusiasts. Though they are often much less expensive than many performance aftermarket parts, quality is not compromised. High performance racing parts and accessories from a company built by racing enthusiasts. With a full line of quality suspension, braking, and other parts, it's easy to customize your vehicle while giving a unique driving experience.
Made from aircraft quality aluminum, these precision machined components incorporate an OE style bearing within a bonded urethane insulator that doesn't rattle or loosen up like a spherical bearing will.
Providing as much adjustment capability as anyone should ever need, these are equally at home on the street or on the track.
Front Camber/Caster Adjustment Range:
Camber: -2.0 to +2.0
Caster: -.75 to +.75
Best,
Joe
Old 05-13-2011, 12:51 PM   #5
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
The camber plates should not interfere as long as the studs on the camber plates are long enough.
Depends how low you want to go but I don't think you need them.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 05-13-2011, 01:08 PM   #6
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
My car won't quite get into alignment with H&R Race springs. I run just a hair too much negative up front.
Old 05-13-2011, 04:00 PM   #7
FTWeisse
My Ride: has no hip-hop rimz
vorshlag camber plates.
Old 05-13-2011, 04:43 PM   #8
aggieE46
Keep it clean
aggieE46's Avatar
Gospel
Old 05-14-2011, 03:12 PM   #9
BMW_Matt
My Ride: 135
Lol @ UUC camber plates.
If you need/want to go more than -2, get vorschlag plates. Excellent quality.
BMW_Matt is offline   Reply With Quote
Old 05-15-2011, 01:08 PM   #10
FTWeisse
+1 - I'm not a fan of UUC - I don't know why people are on the UUC bandwagon.
Old 05-19-2011, 01:49 PM   #11
Masonbarnard
My Ride: AW 04 Sti - gt3076r
UUC ive heard good things about. i think you should do it before you throw on coils and regret the action of not having camber plates. i think i saw a thread about modding the stock camber plates some how. not sure if im mixing up the thread i read on it
GT30r Sti > M3
Masonbarnard is offline   Reply With Quote
Old 05-20-2011, 02:12 AM   #12
dbiker207
My Ride: dakar yellow e46 m3
you could always switch the right and left stock plates. i think it gives you about -2.5 deg of camber
dbiker207 is offline   Reply With Quote
