#1 |
Sun Visor Sticker Removal Reccomendation
After "researching" here on the forums I tried using NAIL POLISH REMOVER and COTTON BALLS to remove these stickers. (The Airbag warning stickers on the sun visor)
They came right off but did leave a bit of shiny residue. For removal of the residue I sat a half-nail-polish-saturated cotton ball ontop of a shiny part, let it sit there for 30-60 seconds, then scrubbed it in a circular motion with a paper towel. Not sure if anyone actually cares, but if you haven't removed your stickers it is an easy and free DIY. (Don't expect your visors to look perfect though!)
#2 |
Since the ZHPs and M3s come with cloth visors it's actually a little easier. Use a hair drier to heat up the sticker, and start peeling at the corner. Pull gently as the glue melts. If you're good, it should come off as a single piece.
There will be residue in the shape of a sticker left over. What I did to get rid of that was to use a steam press to heat up, and then a towel to lift the glue. Had to repeat that process a few times. Can barely tell the stickers were ever there now |
#3 |
would an iron be an okay substitute for a steam press?
![]() ________________________ |
#4 |
Mod
I don't see why not.
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
