Old 05-11-2011, 11:20 PM   #21
Saintly
My Ride: ....
I ran the Ixu27's but they fould pretty quick unless you were full tilt all the time. I now run IXU24-01's and have zero issue's. my 2cents
Gone to new home:-
Fastest ET 11.41@126.09mph
Highest MPH 129.49mph
Highest HP 631rwhp Dynodynamics
Saintly is offline   Reply With Quote
Old 05-11-2011, 11:39 PM   #22
TaZaM3
Psshhhht M3
My Ride: E46 M3
I think the ixu24's are too hot for the higher hp s54 applications. Also depends on your ignition system and type of coils used.
TaZaM3 is offline   Reply With Quote
Old 05-12-2011, 09:32 AM   #23
Providence
My Ride: HPF Stage 3 m3
Send a message via MSN to Providence
Well r2525-10 s if you r runin rich like me die fast because of the carbon build , denso ixu 27 s last a bit longer
Providence is offline   Reply With Quote
Old 05-12-2011, 09:45 AM   #24
yellowssm
My Ride: 2005 M3
Originally Posted by MarcusLSB View Post
That would be incredibly helpful. I'm pretty sure I'm running rich though, at mid 12's at idle.
That does sound rich. Although I'm not a stg 2.5, my car is 13.5-13.8 at idle
yellowssm is offline   Reply With Quote
Old 05-12-2011, 09:59 AM   #25
TaZaM3
Psshhhht M3
My Ride: E46 M3
My car also idles below 14, pretty much the same as yours. I don't see any problems with that. We bumped it up to 14.5ish and the car just didnt like it for some reason. It was running very odd when trying to take off.
Old 05-12-2011, 11:59 AM   #26
InDiGlOM3
My Ride: HPF M3 stg 2.5
I think just the stage 1 runs these, any thing more and it dont like them.
as with taz and 02black I idle at 13.2-13.8
Old 05-12-2011, 12:13 PM   #27
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Edit: Nevermind. Saw it in an earlier post.
Just ordered the IXU27's and had them overnighted. I'm going to give them a shot, I can't be spending $250/mo on NGK R's..
Old 05-12-2011, 12:16 PM   #28
InDiGlOM3
Ixu27 just like Taz, as I said before I used what you have now but they did the same thing. However they might be what you need or work for you if you dont run so rich, your idle seems rich if its in the 12's all the time.
Old 05-12-2011, 12:41 PM   #29
TaZaM3
Psshhhht M3
My Ride: E46 M3
Im pretty sure its obvious the IXU27's are the way to go! Our cars are very sensitive with everything though, changing plugs will be a regular thing.
Old 05-12-2011, 12:43 PM   #30
MarcusLSB
Thanks Taza. I'm totally fine w/that but I felt 1000mi between plugs was just a little much when the plugs are 250.
Old 05-12-2011, 01:01 PM   #31
InDiGlOM3
Yeah those plugs are expensive, thats why I just went back to the Ixu27's I change them every 10k miles re gap every 5k
Old 05-12-2011, 01:05 PM   #32
TaZaM3
Psshhhht M3
My Ride: E46 M3
Ya with the ixu27's you should get more then 1000 miles, it depends alot on your driving style as well. Ive replaced them only once after 4-5k miles or so of lots of race gas driving.
Old 05-12-2011, 01:15 PM   #33
MarcusLSB
I don't know how you guys drive but I occasionally well get on it a bit getting onto the freeway etc.. but otherwise I drive like a normal person. Maybe thats why these plugs were fouling, that and I'm pretty sure I'm running a little rich.
I'm going to take the car out here for a 75mi journey to San Francisco.. I'll be monitoring my AFR's etc
Old 05-12-2011, 01:48 PM   #34
02black330ci
My Ride: spaceship
Are you doing the drive before or after the new IXU27's?
02black330ci is offline   Reply With Quote
Old 05-12-2011, 01:49 PM   #35
Commanderwiggin
My Ride: 1000rwhp Turbo M3
I drove my car quite sensibly for most of my trip down the west coast...1000miles or so...but I have different plugs than you.
Old 05-12-2011, 06:55 PM   #36
MarcusLSB
So here's my results of driving with my NGK R R2525-10's.. (and my possibly rich tune)
AFR's @ Cold Idle - high 10's low 11's..
AFR's @ Warn Idle - 12.5 roughly..
WOT from about 3k - 5k .. generally 12's/11's..
Crusing the highway in 5th or 6th around 3k.. generally high 13's..
I've got the new plugs on the way, won't be here until tomorrow though.
Old 05-12-2011, 07:30 PM   #37
Saintly
My Ride: ....
Even while spraying I run these, but it's the 01's that have non protruding tips that protect them. Plasma coils.
I also Idle at the same mixture.
Gone to new home:-
Old 05-12-2011, 08:16 PM   #38
InDiGlOM3
Im not sure for stage 3, but all those AFR's seem off.
Old 05-12-2011, 08:26 PM   #39
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
NGK BKR7EIX, One Step Colder.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-12-2011, 08:27 PM   #40
TaZaM3
Psshhhht M3
My Ride: E46 M3
Warm idle seems too rich. The rest is ok.
