Sponsored by BimmerWorld
Old 05-12-2011, 11:41 PM   #1
tyty
My Ride: AAstage1 330i
What Brake Pads Should I Get??
I'm going to replace all my pads and I can't decide what to get. I'm looking for a good balance between cost performance and wear. Any help or suggestions will be greatly appreciated.
Thanks,
Ty
tyty is offline   Reply With Quote
Old 05-12-2011, 11:55 PM   #2
808ZHP
My Ride: '03 330i ZHP
Akebono
SG 330i ZHP Alcantara 6MT Rogue LED V1
808ZHP is offline   Reply With Quote
Old 05-13-2011, 12:29 AM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Thanks,
Ty
If your street diving it, and not tracking, stock pads work great. If you still want an upgrade, go with Performance Friction "Z" Rated front pads & stock rear. Rember that your front brakes carry between 70 to 75% of the braking load on your Bimmer.
Forum sponsor BimmerWorld has them:
http://store.bimmerworld.com/perform...pads-p721.aspx
They also have Performance Friction street brake pads on sale for half off.
http://store.bimmerworld.com/perform...ads-p1074.aspx
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-14-2011, 04:13 PM   #4
BMW_Matt
My Ride: 135
Was about to recommmend the same thing, Rob. They will be my next pads - plus they're pretty damn inexpensive.
BMW_Matt is offline   Reply With Quote
Old 05-14-2011, 05:48 PM   #5
tyty
Good luck.
Thanks a ton for that just ordered those and there going on this week sometime!
Old 05-15-2011, 02:07 PM   #6
FTWeisse
My Ride: has no hip-hop rimz
I know you've already ordered your pads, but in the future you could also consider Carbotech pads - they are cheaper than the PFBs and the quality is the same.
Old 05-17-2011, 12:54 AM   #7
TopazBlu02
My Ride: 330CI
How good are the regular PF street pads compared to the more expensive "Z" rated version? Bimmerworld has them for $40 so it's very tempting but are they even worth giving a try. I just want OEM bite with LESS DUST!
TopazBlu02 is offline   Reply With Quote
Old 05-17-2011, 09:01 AM   #8
BMW_Matt
My Ride: 135
Stop being lazy and trying to sacrifice performance for some damn dust. Just get a wax on the wheel and it wipes right off....
Old 05-17-2011, 09:08 AM   #9
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Check out HAWK pads...
A premium high performance ultra-low dust low noise compound
Ultimate stopping power in an ultra-low dust low noise ceramic compound!
Hawk Performance has introduced a premium high performance ultra-low dust low noise compound called Performance Ceramic.
Performance Ceramic is engineered to reduce brake NVH (Noise Vibration and Harshness) creating a quieter performing brake pad. Furthermore the ceramic brake pad formula has a linear friction profile that allows your ABS brake system to work more effectively. With Performance Ceramic you can expect reduced brake pad wear lower dust output levels and a rotor-friendly brake pad.
Ultra-low dust
Improved braking over OE
Stable friction output
Extremely quiet
Extended pad life
Increased rotor life
Best,
Joe
