Sponsored by The Tire Rack
Old 05-13-2011, 04:28 PM   #1
DJ Reminisce
My Ride: Knows Dubstep SUCKS
Question Tire Experts, PLEASE help! Style 135 questions
Tire experts, please help me figure out what will fit given my current setup and where I want to get it:
Current setup:
(Rear fenders rolled)
18x8 F
225/40/18
18.8.5 R
255/35/18
My question is, how much of a stretch do I need if I plan on dropping the car on either H&R Sport springs or on Eibach Sportline springs? (I realize they both have different drop specs, so let's air on the side of caution and go conservative)
I currently have 10mm F and 15mm R spacers, and I would like to push to 15 mm F and 25mm R, giving me an approximate ET of about 32F an 26R
How much of a stretch do I need to get basically flush? I was thinking of going with 225/40/18 in the back, but have no idea what size to get for the front (215/40/18?). I've been told that the fronts should be ok even with stock tire sizes?
Also: I don't want to loose a lot of ride height by stretching too much, as I'm already worried about what the ride height will be once I'm lowered.
Any help is GREATLY appreciated! If you have pictures to illustrate to me what the stretch, if needed, would look like, that would be great. I've seen some pics, but more never hurts.
Dinan CAI_Stage II_3.46 Dif
OEM CF Strut Bar_Eibach Sportline_GC Konis
OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters
Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems
500W_RE Audio_Hertz Components
DJ Reminisce is offline   Reply With Quote
Old 05-16-2011, 09:56 AM   #2
DJ Reminisce
Damn, nobody?
Old 05-16-2011, 10:48 AM   #3
DJ Reminisce
Ok, well, what If I make it a more straight forward question:
Do I need 225/40/18 or 235 in the back if I plan to drop on Eibach Sportline and space to an et26 rear?
I don't jack about tire stretch, but from what I've seen, the 225/40/18 on the back should be fine. Just wondering If I can put a 235
Thanks for anyones help
Old 05-16-2011, 01:21 PM   #4
DJ Reminisce
Guess I'll just have to create a thread in the General section
lame
Old 05-16-2011, 01:26 PM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
An 8.5 ET26 should fit with a bit of fender work. Since your car has rolled fenders it probably would be alright, but it just depends on how flat you were able to get the fender lips.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 05-16-2011, 01:36 PM   #6
DJ Reminisce
Thanks man
Yeah, I know nothing about tires, and I really don't want to buy the wrong sized ones, especially after spending $ on larger spacers.
The rears are only rolled, not cut, so I still have about a 5-7mm lip in the back
If I go with a 225/40/18 on the rear, and with the fenders being rolled, do you think the stretch will give me enough clearance?
Old 05-16-2011, 03:16 PM   #7
VMRWheels
VMRWheels's Avatar
You could probably clear with those tires since you have already done some fender work.
Old 05-16-2011, 03:43 PM   #8
DJ Reminisce
You are referencing the 225/40/18s, correct?
Old 05-17-2011, 01:14 PM   #9
VMRWheels
VMRWheels's Avatar
Yes, the 225/40/18s would most likely fit without too much trouble.
Old 05-17-2011, 01:55 PM   #10
DJ Reminisce
Thanks so much man, really appreciate it
