Control arm bushings opinion needed! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 05-15-2011, 11:20 AM   #1
nedined
My Ride: 04 330Xi & 06 ML350
Send a message via MSN to nedined Send a message via Yahoo to nedined
Please, take a look at the pics and let me know if the bushings are siting right or they are sticking up front? Is this normal or do they need to be pushed back? Why is this happening? Both sides are like this:
nedined is offline   Reply With Quote
Old 05-15-2011, 11:39 AM   #2
Kubica
My Ride: 2003 325xi
What kind of bushings are those?
Looks like they arms were pushed too far into the bushings, causing the bushing to pull out when everything was tightened down.
Old 05-15-2011, 11:45 AM   #3
nedined
These are PowerFlex Bushings for Xi. How can I fix that?
Old 05-15-2011, 12:01 PM   #4
Kubica
My Ride: 2003 325xi
I would undo the bolts that hold the FCAB bracket, then push the part of the bushing that sits around the control arm backwards toward the end of the arm a little bit. Use water not grease if it's tough to slide back on the arm. Make sure you do regrease between the two pieces of the FCAB.
When were those powerflex purchased? I didn't know they were purple now.
Old 05-15-2011, 12:20 PM   #5
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
yea. the piece on the control arm is pressed on too far. what kubica said is correct. I just looked at mine and i have a gap between the end of the control arm and the bushing. Also, mine are black and i got them 2 years ago. Id check to make sure they are the right bushings as well.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 05-15-2011, 12:35 PM   #6
Kubica
My Ride: 2003 325xi
Yeah, you have the e36 m3 bushings like me, right?
I know the really old powerflex first gen bushings were purple.
Old 05-15-2011, 01:33 PM   #7
wdeerfield
wdeerfield's Avatar
Yes, mine are all black with the hole centered. If those purple ones are original first gens, they held up great!
Old 05-15-2011, 01:42 PM   #8
Kubica
My Ride: 2003 325xi
^ I think the first gens were one piece.
Old 05-15-2011, 04:35 PM   #9
nedined
I purchased them Sep. or Oct 2010 I believe from Bavarian AS if I'm not mistaking but I think they had little black around them too... I'll make more pics ones I get to fix them to show you. I remember the hole was not in the center and it was on purpose.
What should I use to regrease?
Old 05-15-2011, 04:51 PM   #10
nedined
Actually I bought them from bavauto.com for sure. This is the part number: PFF5-4601XI - Powerflex Control Arm Bushing - Urethane - Sold as a pair. $69.95.
Old 05-15-2011, 06:05 PM   #11
Kubica
My Ride: 2003 325xi
^They use ordinary copper grease , I believe.
Old 05-15-2011, 07:05 PM   #12
wdeerfield
wdeerfield's Avatar
Yes, copper anti seize grease works.
Old 05-15-2011, 11:14 PM   #13
nedined
Ok. Thanks guys!!! Tomorrow I'll be doing this. Would I need to do alignment after that or it should be fine?
Old 05-16-2011, 06:00 PM   #14
Kubica
My Ride: 2003 325xi
^ Tough call. I would get one since toe will most likely be out on both sides. Depends on how much you like your tires I guess.
Old 05-16-2011, 07:54 PM   #15
nedined
I went today to Auto-zone, Advanced Auto Parts, O'reilly and Wal-Mart to buy copper anti seize grease and none of these had it. So where should I look for it?
Old 05-16-2011, 08:34 PM   #16
Kubica
My Ride: 2003 325xi
http://store.powerflexusa.com/powerf...ket-p1145.aspx
Old 05-17-2011, 06:18 AM   #17
325xittt
My Ride: 2003, 325 XIT
The Bentley Manual suggest that the distance from the the edge of the 1st bore hole in the control arm to the outer edge of the bushing housing should be 170 mm +- 1 mm.
325xittt is offline   Reply With Quote
Old 05-17-2011, 02:16 PM   #18
nedined
Excellent information, thank you!
Old 06-23-2011, 08:11 AM   #19
association16
My Ride: 2003 BMW 330xi
What else could you use the copper anti seize grease for? Or would you only use it for the bushings?
association16 is offline   Reply With Quote
Old 06-23-2011, 09:06 AM   #20
wdeerfield
wdeerfield's Avatar
you can pick it up at sears. or via here: http://************/5uqofm7
