Old 05-15-2011, 07:25 PM   #1
thefrog1394
My Ride: e46- 1999 323i
o2 Simulator circuit DIY
http://www.mkiv.com/techarticles/oxy...sor_simulator/
FYI this o2 simulator circuit fools our computer successfully, just tried it out on my car. For those who don't mind some soldering it can be built for quite a bit cheaper than the o2simulator.com type o2 sims.
Photo in Cleveland, Ohio
1999 323i - Totaled at 265,000 miles.
Now an e30 & e90 owner.
thefrog1394 is offline   Reply With Quote
Old 05-15-2011, 08:26 PM   #2
aeathb
My Ride: 2005 bmw 325i
I hope this isn't a bad question, but if you created a circuit to "fool" the ECU into thinking it is using an O2 sensor when its not, wouldn't that make the car run too lean/rich or just less efficient?
aeathb is offline   Reply With Quote
Old 05-15-2011, 08:46 PM   #3
SweTurbo
Big Pimpin'
My Ride: 323i -98
It's just for the post cat sensors , so that you can run headerless without throwing a CEL / Status not ready.
Old 05-15-2011, 08:47 PM   #4
aeathb
I have always wondered what I would do if I put on headers. So they are only for emissions control I take it?
Old 05-15-2011, 09:14 PM   #5
thefrog1394
The only purpose of the post-cat o2 sensor is to detect whether the catalytic converter is functioning properly. This simulates the signal that the o2 sensor would send when the cat is functioning properly. (well simulates it close enough to fool the DME)
And yes, this is for simulation the post-cat o2 sensor only. Simulating a pre-cat o2 sensor would do all kinds of bad.
Old 04-04-2012, 09:55 AM   #6
cposk
My Ride: 08' E90 M3
Sorry to revive an old thread, but 2 questions for the OP.
Did you use 1/4w resistors? And did you have to simulate the heater circuit or did you leave the o2 sensors plugged in.
I have a month to get my emissions done and this is going to be the cheapest route.
cposk is offline   Reply With Quote
Old 04-09-2012, 04:57 PM   #7
thefrog1394
I do not recall what the power rating on the resistors was that I used, but the signal lines don't carry much power so 1/4 watt should be fine I would imagine. And yes I just used the old sensor's heater instead of simulating a heater circuit
Old 05-21-2012, 10:27 AM   #8
Mark M
My Ride: e30 M3 / e90 335d
I just used the MKIV link this weekend and soldered up the circuit. Installed it yesterday. Fingers crossed...hoping the Check Engine light will finally stay off.
Mark M is offline   Reply With Quote
Old 05-21-2012, 10:50 AM   #9
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Post cat o2's DO also do fuel mixture control.
You are incorrect I have posted it a few times let me try to find the post.
here it is
Here you go straight from BMW's trianing manuel puts any agruments to bed LOL
POST CATALYTIC CONVERTER SENSOR SIGNAL
The post catalyst O2 sensors monitor the efficiency of the catalyst as a requirement of OBD
II. This signal also provides feedback of the pre-catalyst sensors efficiency and can cause
the ECM to "trim" the ms injection time to correct for slight deviations.
Bosh Systems:
If the catalyst is operating efficiently, most of the
remaining oxygen in the exhaust gas is burned
(lack of O2 - "constant lean signal***8221.
The sensor signal fluctuates slightly in the higher
end of the voltage scale.
If the post sensor shows excessive fluctuations
(which echo the scope pattern of the pre sensor),
this indicates that the catalytic converter is not
functioning correctly and cannot consume the O2
(fault set).
If the post sensor fluctuations move out of the normal voltage "window", this indicates
that the pre sensor is not performing properly due to slight deterioration. These systems
can also "trim" the ms injection time to compensate for this.
The constantly changing oxygen sensor input to the ECM is needed to correct the ms
injection time to ensure that the ideal air/fuel ratio is maintained.
20
Engine Management Systems
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 07-16-2012, 02:04 PM   #10
thefrog1394
Interesting, though sounds to me like they only really have an effect if the pre-cat sensor is starting to deteriorate.
Anyways I've not had an issue running without my own post-cat sensor. No gas mileage issues or anything else.
Old 07-16-2012, 04:52 PM   #11
joshzhp
My Ride: ZHP--Stock
I remember a post about the signal output changing...will this work on an 2003 model?
joshzhp is offline   Reply With Quote
Old 07-22-2012, 08:53 AM   #12
wildcat293
My Ride: 325xi
I think that sounds right. As long as the simulator makes the ECU think the post cat is working properly, nothing is tuned/detuned.
wildcat293 is offline   Reply With Quote
