Sponsored by The Tire Rack
Old 05-15-2011, 09:59 AM   #1
jclip
Location: Founder of the uber-rare body color roof club
My Ride: 01 330 CI
Help needed with tire/wheel fitment
I have an 01' 330ci coupe. I have my eye on a set of 18x9 rear wheels. My question is, what tire size should I run if I want a very mild stretch? The company I am dealing with recommends a 245/35/18, but I think I should go with a 235 wide tire?
jclip is offline   Reply With Quote
Old 05-15-2011, 11:45 AM   #2
Andy2108
My Ride: E46M3E92M3'67Cobra
245 is fine, 235 might be a bit more stretched. Im running 255's on 18x9.5"s
Crappy pic, but its got very slight stretch to it
I'd recommend 245, however anything from 225 to 265 would be within the factory specs of the tire for a 9" wide wheel.
If you want stretch, go 235
De gustibus non est disputandum.
Old 05-15-2011, 02:06 PM   #3
2003 325i
My Ride: '03 Orient Blue 325i
What size are your fronts? Still want to have close to the same OD of the wheels front to rear.
Old 05-15-2011, 02:09 PM   #4
Andy2108
Mine? Im running the BMW recommended tire sizes for 18" wheels on my car. 225/40/18 front and 255/35/18 rear. Because our cars are rear wheel drive, small variances in size front front to rear should be fine.
Old 05-15-2011, 05:07 PM   #5
JHW330ci
My Ride: 330ci vert, 330i
Fitment comparison website
You might find this website useful in comparing width, height and wheel well fit between different size rims and/or tires: http://www.rimsntires.com/specs.jsp.
JHW330ci is offline   Reply With Quote
Old 05-15-2011, 06:42 PM   #6
2003 325i
Was asking OP about tire size.
Old 05-15-2011, 07:50 PM   #7
jclip
My Ride: 01 330 CI
Its a 9" rear wheel, 40mm offset. I was told by the dealer to run a 245.
Old 05-15-2011, 08:53 PM   #8
2003 325i
You don't understand... what is the size of your front tires? Need to maintain close to same outside diameter.
Old 05-15-2011, 09:18 PM   #9
jclip
My Ride: 01 330 CI
Originally Posted by 2003 325i View Post
you don't understand... What is the size of your front tires? Need to maintain close to same outside diameter.
225/40/18
Old 05-15-2011, 09:26 PM   #10
Paul Schreiber
My Ride: Siennia red 330CiC
I had this setup on my 330Ci and it handled well plus the spedo was dead on. Down side is ride quality dropped alot. Seemed like every bump came with a jiggle or squeak... I went back to stock size 17s and maintain great handling with the BMW quality ride. Good luck with the new wheels.
Paul Schreiber is offline   Reply With Quote
Old 05-16-2011, 12:06 AM   #11
2003 325i
How wide are your front wheels, and do you have a pic of the stretch on them (if there is any... assuming 8.5" wheel)? I'd go with a 235/40 in the rear for some mild stretch
Old 05-16-2011, 12:26 AM   #12
Andy2108
Tires make such a huge difference... I'm running pretty aggressive GoodYear Eagle F1 Asymmetrics and the main difference between them and my 17" General snow tires is noise: the 18" are WAY louder, but maybe its just cause the snows were so quiet?
I love the look of my 18" VMR VB3 CSL wheels and I would gladly give up some ride quality for the increased performance and visual appeal
Old 05-16-2011, 12:51 PM   #13
VMRWheels
VMRWheels's Avatar
My Ride: 1:25 Scale Enzo
A 245 would probably be the most decent looking if your car is at stock height.
Kevin @ VMR | Wheels
Tel: 714-442-7916 | Email: kevin.a@velocitymotoring.com
Facebook! | Flickr! | Blog!
Old 05-16-2011, 07:04 PM   #14
jclip
My Ride: 01 330 CI
Its currently on H&R race springs.....And the fenders have been cut/pulled/rolled.
Old 05-17-2011, 12:17 PM   #15
VMRWheels
VMRWheels's Avatar
I'd probably stick with a 245 still.
Old 05-17-2011, 04:22 PM   #16
2003 325i
Front wheels 8.5" wide, go with 235/40s, Front wheels 8" wide, go with 245/40s. This is only for maintaining the same amount of stretch look front to rear, otherwise I defer to Kevin's expertise. The 245/40s would likely be closer to stock diameter with that stretch, however the 235s would be more similar to the diameter of the fronts (both undersized slightly) if the fronts are on 8.5" wide wheels.
