Old 05-16-2011, 08:59 AM   #1
Usmc1028
My Ride: 1999 BMW 328i
How to turn DRLs off?
Is there any way i can turn the daytime running lighta off myself?
Usmc1028 is offline   Reply With Quote
Old 05-16-2011, 09:10 AM   #2
stevenluczynski
My Ride: Is Steel Blue
Nope. Dealer will charge 150$
stevenluczynski is offline   Reply With Quote
Old 05-16-2011, 11:27 AM   #3
El Polo
My Ride: 99 black 328i
Yes, but it is not as easy as you may hope. You would need a computer with proper coding software, and an OBD cable supporting specific protocols (I can't tell you more, I don't fully understand how it works yet).
Then you need a lot of patience because you will be dealing with German abbreviations and tons and tons of settings. And screwing one could have effects that would make you regret trying to DIY.
If you have the patience and want to know more, start reading there.
El Polo is offline   Reply With Quote
Old 05-16-2011, 11:33 AM   #4
Usmc1028
Thanks yall i like the $150 route
Old 05-16-2011, 11:36 AM   #5
El Polo
Well, if you have a good indy that has the computer and the knowledge, it should be cheaper than $150. You might get pretty upset when the dealer charges you that amount after hooking up a computer for 2 minutes maximum...
Old 05-16-2011, 01:02 PM   #6
SWFan
My Ride: 2011 335is
The dealer in KC only charged me $35. Don't assume your dealer charge is the same charge across all dealers.
2011 BMW 335is
SWFan is offline   Reply With Quote
Old 05-17-2011, 02:54 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Find a local fanatic with the GT1 tool. Regardless, you shouldn't pay more than $50.
Old 05-22-2011, 08:33 AM   #8
TheKingSim0n
My Ride: BMW 325i
Send a message via AIM to TheKingSim0n
Any local shop with an updated ODB computer for BMWs would be able to do this.
TheKingSim0n is offline   Reply With Quote
Old 05-22-2011, 10:13 AM   #9
theinfamousdrew
My Ride: 911 Turbo / E70
i can do it if you're ever in charlotte....also there is a fanatic up in greenville nc that can do it
theinfamousdrew is offline   Reply With Quote
Old 05-22-2011, 09:46 PM   #10
Usmc1028
How much man?
Old 05-25-2011, 05:09 AM   #11
theinfamousdrew
pm'ed
Old 05-25-2011, 04:28 PM   #12
sharpx
My Ride: E46 330i
DRL's can be turned off using Autologic/GT1/NCS. Most euro indy shops tend to have Autologic computers.
sharpx is offline   Reply With Quote
Old 06-07-2011, 10:10 PM   #13
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Buy P.A.Soft from dealextreme: http://www.dealextreme.com/p/bmw-sca...on-1-4-0-51768 just $48
That will do the trick.
Nervous is offline   Reply With Quote
Old 06-07-2011, 10:48 PM   #14
stevenluczynski
wow i have never seen this!
