///M3 Forum
Old 05-17-2011, 10:38 PM   #1
fat-marshmellow
My Ride: ///M3 SMG
p0012 p0014 codes need help, yes searched...
i need help asap!
so a couple days ago my car ran fine for the day, shut off the car at the lake went fishing for a couple hours, came back started the car...let it sit idle for about a minute all of a sudden it starts to shutter and shake, rpm was constant...it threw me a cel, it drives fine but just weak. i got the codes read and i got these codes...p0012, p0014, p0300 (misfires random cylinders...) as far as my research goes, it might have something to do with the vanos solenoid? but from the service records, both inlet and outlet vanos systems were replaced back in october 2010 from motorwerks bmw....not even a year old yet...any inputs or thoughts to why my cars doing this? sorry i tried searching but only half of it is answered...
ex: 2002 TIAG 325xi (sold), 2007 suzuki gsxr (sold)
current: 2002 carbon black ///M SMG
halogen headlights? want hid projectors? on a budget? maybe i can help! go here!!
http://forum.e46fanatics.com/showthread.php?t=840919
fat-marshmellow is offline   Reply With Quote
Old 06-27-2011, 11:01 PM   #2
fat-marshmellow
My Ride: ///M3 SMG
some help please? =( been over a month and i still havent figured it out...ive replaced the vanos solenoid, replaced the intake cam sensors, still nothing, same codes keep popping up same problems =(
Old 07-15-2011, 12:24 AM   #3
larry driver
My Ride: 06 m3, 06 330i zhp
Intake cam bolts, exhaust vnos oil pump drive lugs
larry driver is offline   Reply With Quote
Old 08-25-2011, 11:23 PM   #4
nedined
My Ride: 04 330Xi & 06 ML350
Send a message via MSN to nedined Send a message via Yahoo to nedined
Did you figured it out yet? I have the same problem and CES light with P0014. I changed the solenoids, sensors, seals, checked the timing and no improvement. I have no idea what else I can do
nedined is offline   Reply With Quote
Old 08-26-2011, 01:02 PM   #5
$ilent ///M
My Ride: 03.5 M3 smg lsb
OP: There is a TSB out for upgraded Bremi Coils if you have Bosch then your ok.. sounds like one or more of your coils may have failed. Also they extended the warranty on these i do believe. I can get you the information if you like.
$ilent ///M is offline   Reply With Quote
Old 02-05-2013, 09:35 PM   #6
Iebimmerguy
My Ride: E3,E23,E38
Following up on your posy
i need help asap!
Did you even figure out your P0012 code on the M3? I have the exact issue now....
Thanks!!
Iebimmerguy is offline   Reply With Quote
