Sponsored by BimmerWorld
Old 05-17-2011, 11:27 PM   #1
BMW_Stu
My Ride: HPF 330ci
How low can you go on Bilstien b8 or HD
i have 2 worn out rear coilover shocks, i'm lowered about 3 inches in the rear. i have been told that i can make the bilstiens work by cutting the bump stops...
Can bilstiens really go that low without pretty much killing them? whats the difference btw sport and HD?
BMW_Stu is offline   Reply With Quote
Old 05-17-2011, 11:45 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Raceland problem ?
Anyway:
HD, are for regular height springs.
Sport, shorter performance springs
Bilstein Sports are what you want, and yes they work low like that. If you are forced to cut the bump stops, try to only trim them. I've blown out Bilstein Sports with No bump stops.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-18-2011, 01:17 AM   #3
BMW_Stu
My Ride: HPF 330ci
i have K-sports, it's a great kit but lame customer service. I had a defective strut, tried to get it replaced under warranty and they pretty much screwed me over and sent me "replacements" that were just as bad as the ones i sent in. I'd live to just replace w/ another set of k's but you can't buy coilovers in separate pieces.
