E46 Xi Forum
Old 04-20-2015, 03:32 PM   #1
DRA2120
My Ride: 03' 330 xi
front end shake thread #9678926398
I know there a 9,000,000 threads about this, but I'm a little confused and I'm hoping someone can offer advice. I've had a front end shake under acceleration between 2k-3K since I bought the car, (which was only about 2 months ago). I had a local shop look at the car, and they told me the front drive shaft was the culprit. So this last weekend, I swapped the front drive shaft in the car with a used, good condition unit. The old drive shaft was definitely bad, as the front u joint was totally locked in one direction. My issue is the front end shake is now worse than it was before. I think my axles are bad, because I can hear clicking on tight low speed turns, but why would fixing at least part of the problem make the shaking worse?
DRA2120 is offline   Reply With Quote
Old 04-20-2015, 08:25 PM   #2
djdonis
My Ride: e39 540i M, 330i 6sp
That's how it usually goes - fixing one loose end exaggerates all the rest of them. Now you have to continue changing all your suspension components with brand new OEM. I guarantee you that when all you have left to do is to change $10 bushing you will sell your car.
Diagnosis - BMW...
djdonis is offline   Reply With Quote
Old 04-21-2015, 04:47 PM   #3
Tlrtucker
My Ride: 2003 330xi
Or - maybe more than just the drive shaft was the problem. Front control arm bushings are extremely common problem areas. Mine had your exact symptoms - new FCAB's reduced the shaking about 90%. Inspected my front cv axles and noticed the boots were split, but no grease was thrown out or anything so I decided to just keep an eye on them and see what they do. Over the next 1,000-1,500 miles the vibrations slowly increased. I finally decided to quit tempting fate and replaced them and everything was smooth as glass...
Tlrtucker is offline   Reply With Quote
Old 04-22-2015, 08:57 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Axles, they are also temperature dependent, the colder it gets, the worse the problem is.
If the CV joint boots are split, its time for axles.
Also DO NOT use cheap Asian $70-$90 parts store axles, not that you can get them for this where you are located.
Get GKN axles from ECS Tuning.
Old 04-23-2015, 02:56 PM   #5
awszach
My Ride: 2001 BMW 325xit5mt
Thanks for post. I got the bad shake. gonna get on the new cv joints real soon, axle as well, within the next couple weeks. After that is suspension so its looking like I should have a pretty smooth summer
awszach is offline   Reply With Quote
