Sponsored by The Tire Rack
Old 05-19-2011, 10:05 AM   #1
GreekLSBm3
My Ride: drops panties
hub c rings
I tried looking online and searched everywhere but couldnt find any info on the size I need. I have HP design 20" flight wheels on the car and there is a slight vibration at a certain mph. I've eliminated 90% of the problems that it could have been and now I am fairly confident that the wheels need hub centric rings. Does anyone know what size I need or I have to contact the manufacturer to figure that out ?
360 Gamertag - GreekM3
GreekLSBm3 is offline   Reply With Quote
Old 05-19-2011, 03:18 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
It would be best to contact the manufacturer to see what size the bore is on your wheels, however you can also find out the same information by measuring it. As long as you can find an accurate way to measure the width, you should be able to find the right ring for your needs.
If you can get your hands one one of these that is small enough to fit in your wheel and make accurate measurements, you should be fine.
Also for reference, your hub size is 72.6mm.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
