Sponsored by BimmerWorld
Old 05-19-2011, 09:03 PM   #1
Matt Jensen
My Ride: E46 SCCA T2 racecar
M3 master cylinder interchangeablity
I have a 2001 M3 T2 racer, need to replace the master cyclinder. I have a 2004 donor car, are the masters interchangeable. I understand the ABS pump is different and located opposit side inner fender area, but need a master asap. Car has been bled numerous times, including with Auto Logic program. Car has a stiff pedal when motor is off, long pedal when running. We are getting zero codes with the ABS and appear to be using more front brake than rears...
Matt Jensen is offline   Reply With Quote
