Old 05-20-2011, 05:30 PM   #1
M3Monsta
My Ride: E36 S54
Cross drilled Rotors?
Just a quick question, what is the difference between normal rotors and cross drilled? (Physical difference) And what are the differences in performance (if there are any)
Also, is there a big price jump?
Thanks.
M3Monsta is offline   Reply With Quote
Old 05-20-2011, 05:34 PM   #2
OrientBlau
My Ride: 2003 330i
There's blank (standard), drilled and slotted.
Blanks work the best. Period.
Blank:
Drilled:
Slotted:
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 05-20-2011, 05:36 PM   #3
dan_1337
My Ride: 330CiC
One has holes drilled through them, one is a solid piece of steel.
From what I've seen, braking distance isn't decreased but the rotor can run cooler as it has more vents than the standard vented rotor.
Yes and no. Depends on brand, model, etc.
dan_1337 is offline   Reply With Quote
Old 05-20-2011, 05:40 PM   #4
Andy2108
My Ride: SpecE46 & E46 M3
true, but they look so damn good
blank - best, reason they are stock
slotted - faster cooling, slightly less surface area than blanks
drilled - less surface area than blank's. faster to warm up and faster to cool down. possibility to crack with crazy heat on the track after alot of abuse
and they just look sooo much cooler
De gustibus non est disputandum.
Old 05-20-2011, 05:43 PM   #5
grandcarrera
My Ride: 330xi 2003
So you say that I should get normal oem rotor over oem performance rotor ?
grandcarrera is offline   Reply With Quote
Old 05-20-2011, 05:45 PM   #6
El Polo
My Ride: 99 black 328i
^those are cast perforated rotors if I'm not mistaken. They don't have the weakness of cross drilled ones by design.
El Polo is offline   Reply With Quote
Old 05-20-2011, 05:47 PM   #7
Andy2108
the OEM performance ones are cast perforated?
Old 05-20-2011, 05:49 PM   #8
El Polo
I was replying to your message with the picture of the Brembo kit. No idea about OEM perf ones
Old 05-20-2011, 05:51 PM   #9
Andy2108
That picture was for drool references only.
Old 05-20-2011, 05:52 PM   #10
OrientBlau
My Ride: 2003 330i
Agreed. Drilled does look much better.
Old 05-20-2011, 05:54 PM   #11
El Polo
Zimmermann products seems to be cast perforated (even if vendors advertise them as cross-drilled... marketing...)
Old 05-20-2011, 06:04 PM   #12
3MPOWERED
My Ride: E46 M3
Slotted or not slotted are best. The cross drilled rotors have been known to crack between the holes and eventually grenade regardless of brand. I've seen Dba rotors go boom.
** Removed - Tim330i **
3MPOWERED is offline   Reply With Quote
Old 05-20-2011, 06:34 PM   #13
M3Monsta
My Ride: E36 S54
Well im not planning on going to the track, just a couple street races here and there.
The drilled looks NICE though.
Old 05-20-2011, 07:06 PM   #14
BMWespresso
My Ride: 2005 325CI
drilled, the best performer, never going back no cracks
ID:	404203   Click image for larger version
BMWespresso is offline   Reply With Quote
Old 05-20-2011, 07:13 PM   #15
OrientBlau
My Ride: 2003 330i
Drilled is NOT the best performer.
Old 05-20-2011, 07:23 PM   #16
OrientBlau
My Ride: 2003 330i
What to expect with drilled:
Old 05-20-2011, 07:50 PM   #17
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
you only get cracks from low quality crossed drill. I forgot which one is better (cast vs drilled).
Old 05-20-2011, 08:17 PM   #18
3MPOWERED
My Ride: E46 M3
This has been proven. It is not limited to less expensive brands either. Like I said, I've seen dba rotors do it too.
Old 05-20-2011, 08:37 PM   #19
theOSUbob
My Ride: LeMans Blue E46 M3
I don't think having cross-drilled (or perforated) rotors fail is a COMMON problem. I mean, let's be honest, just about every single high-performance car comes with them standard.
theOSUbob is offline   Reply With Quote
Old 05-20-2011, 08:39 PM   #20
flashmeow
Banned User
word x1000
it is all about how the rotors are made.
