Sponsored by BimmerWorld
Old 05-20-2011, 07:42 PM   #1
Alanz0
My Ride: 325i
Brake pad/rotors changed, don't feel the difference at all
Got my front brake pads and rotors changed at my dealer ( regretting that decision) about a month ago after the brake light came on and I could feel how worn my pads were. I brought it to my dealer in Allentown, PA and asked to see what brakes they were going to change before just doing random s***. The tech showed me the front brake pad which was almost gone and almost to the brake sensor.
Since then I've barely felt a difference in braking force and I feel I still have to press the brakes as hard as I did before. I feel like I wasted my money and I wanted to know what else could cause my brakes to feel worn still?? Also my rear brakes are still good.
Someone told me to brake them in for 500 miles? Any help would be appreciated!
Alanz0 is offline   Reply With Quote
Old 05-20-2011, 07:47 PM   #2
BMWespresso
My Ride: 2005 325CI
Did they flush the old fluid, that helps on pedal feel as well
BMWespresso is offline   Reply With Quote
Old 05-20-2011, 09:37 PM   #3
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
You have the bed the pads in...try Zeckenhausen.com...they have a good tutorial.
After you bed the pads in, they'll bite better.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 05-20-2011, 10:31 PM   #4
Alanz0
My Ride: 325i
Thanks for help fellas, much appreciated. Will check in to doing that!
Old 05-21-2011, 01:06 AM   #5
Steven747
My Ride: 05 330ci
grad some new fluid and ss brake lines that should make it better than new
Old 05-21-2011, 12:09 PM   #6
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by bigjae1976 View Post
you have the bed the pads in...try zeckenhausen.com...they have a good tutorial.
yes. +1
SUMMIT POINT WV 1:24:229 SCCA
Old 05-21-2011, 01:12 PM   #7
Alanz0
My Ride: 325i
It's not too late to bed them in? I saw te process on the website and I feel like having the brakes on for a month it's useless? Is this true?
Old 05-21-2011, 01:31 PM   #8
JordanBMW
My Ride: 320i 2002 steel blue
Send a message via MSN to JordanBMW
Mine stilll make noise when hot. Sometimes even cold, I had them on for 3 months. Is too late to bed aswell?
JordanBMW is offline   Reply With Quote
Old 05-21-2011, 01:37 PM   #9
Steven747
My Ride: 05 330ci
you can rebed brakes at anytime unless your in minimums.. your just making a even flat surface for the contact to the rotors.. you can do it with 20% left
Old 05-21-2011, 09:47 PM   #10
Alanz0
My Ride: 325i
Thanks steven747!
Old 05-22-2011, 12:41 AM   #11
Chris__B
My Ride: Several
Since you probably have the very same compound that came off of the car, there is no difference to feel. "Worn" brake pads will feel the same as new brake pads -- if they are of the same composition. Bedding will help, but it would have helped the old pads, too!
If you want more stopping power, you will have to make changes. The first of which would be a more aggressive pad compound. From there, your wallet and good sense are the only limits (within what the tires are capable of).
Chris
Chris__B is offline   Reply With Quote
