View Poll Results: what would cause you to stop regularly at a stop light and then cant get back in gear
pressure plate 2 15.38%
hydrolics 5 38.46%
bad clutch 9 69.23%
throw out bearing 3 23.08%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Old 05-22-2011, 03:26 PM   #1
cyberlando
My Ride: 2002 M3
Unhappy bmw 330ci 2002 5 speed manual
just driving down the street and pulled over at a stop light and tried to put it in first gear to get going and it will not go into any gears wat so ever.....reverse is a no and 1 to 5.
wen trying to force it, it grinds.......i can presss the clutch to start the car but wen i press the clutch to shift it wont go into any gears......noo sounds wen idling or anything.....just all of a sudden will not go into gear....wat can cause that??
please help!
ID:	404325   Click image for larger version
cyberlando is offline   Reply With Quote
Old 05-22-2011, 03:31 PM   #2
oovvutt
My Ride: 2000 323ci
http://www.bimmerfest.com/forums/sho...d.php?t=501802
oovvutt is offline   Reply With Quote
Old 05-22-2011, 03:52 PM   #3
WheyArea
My Ride: '03 TiAg ///M3
In for response as I have this problem sometimes also
/// Dinan ECU /// Brembo BBK /// BBS LM 19" /// Bilstein PSS10
/// Eisenmann Exhaust /// Supersprint Mid Pip /// AC Schnitzer Spoiler
/// Hamann Lip /// AC Schnitzer CF Diffuser /// K&N CAI /// Valentine 1
Coming Soon...... OEM SSK, CSL bootlid
WheyArea is offline   Reply With Quote
Old 05-22-2011, 03:59 PM   #4
cyberlando
My Ride: 2002 M3
i meannn dudee i swearr i was driving perfectly fineee noo weird sounds noo hitting of a speed bump or anythingg.....then i just pulled over at a light then i couldnt get the car into any gear....i turned it off then turned it back on and tried and nothingg........it goes into gear perfectly wen to cars off but soon as it starts upp not a darn gearr.....im confused on this one the clutch is fairly new so that couldnt be it.....and i havent been dogging it...soo i need somee help on this one......i have a bmw warranty for the hydrolics system like slave cylinder......but some other mechanic is like the pressure plate got stuck which sounds like complete b.s
Old 05-22-2011, 04:59 PM   #5
brainiac
My Ride: 330ci
same goes for me just first gear thou but what i do it put it in 3rd or 2nd and put it back in first
brainiac is offline   Reply With Quote
Old 05-22-2011, 05:09 PM   #6
scottRs4
My Ride: 07 rs4
you need a new clutch. try double clutching and it should build enough pressure to get it into gear. i had this problem on my audi and a new clutch solved the problem.
scottRs4 is offline   Reply With Quote
Old 05-22-2011, 05:24 PM   #7
cyberlando
My Ride: 2002 M3
how do i do that exactlyyyy?
Old 05-22-2011, 05:37 PM   #8
MysticBlau330Ci
My Ride: 330Ci '04 & M4 2016
Will it go into all the gears if the engine is off?
MysticBlau330Ci is offline   Reply With Quote
Old 05-22-2011, 05:41 PM   #9
Stickbuilder
My Ride: Touring, and others
You might be low on the fluid in your clutch master cylinder. If you are, you need to find out why it leaked out. I swear, you kids kill me. You know all about the light mods, and wheel and altered suspension, but have no clue as to what makes your car operate. Get a Bentley manual, and read it.
[/SIGPIC]I'm fluent in 3 languages:
English
Sarcasm
Profanity
Stickbuilder is offline   Reply With Quote
Old 05-22-2011, 05:52 PM   #10
BestOfE46
My Ride: 323,325xi, M3
How do you know this person is a kid?
BestOfE46 is offline   Reply With Quote
Old 05-22-2011, 05:58 PM   #11
cyberlando
My Ride: 2002 M3
loll yeaaaaa it goes into all gears while off but none at all while on!
i mean for me to just stop at a stop light and then bamm nothing at all thats some really off crapp
Old 05-22-2011, 06:16 PM   #12
SweTurbo
Big Pimpin'
My Ride: 323i -98
Then your clutch is the issue.
Throwout bearing would screa if bad.
Clutch disk wont make any diff if bad(apart from not getting you anywhere , but you do seem to have power to the tranny as it grinds gears)
Pressure plate would alow you to shift , just not go anywhere.
Clutch master/slave/hose would make the pedal feel very wierd/drop to the floor.
OP : If you put the car in gear while off , can you start the car in first gear and drive ? (Turn car off , put car in 1st , turn key and car moves?)
If so then something with the clutch manuovering system is bad , if not then clutch assembly is bad.
Old 05-22-2011, 06:32 PM   #13
Stickbuilder
By reading his post, and the majority of the posts that deal with something other then bolt on mods. It is not rocket science. All you have to do is to look at the spelling and choice of words and punctuation. It is not difficult.
English
Sarcasm
Profanity
Old 05-22-2011, 07:10 PM   #14
MysticBlau330Ci
I agree
Old 05-22-2011, 07:37 PM   #15
cyberlando
My Ride: 2002 M3
well if i put it in gear and start the car it does move....so with all being said do most likely my clutch or slave cylinder went bad
Old 05-22-2011, 08:58 PM   #16
scottRs4
My Ride: 07 rs4
to double clutch just push the clutch in twice before you shift it just builds up more pressure. most likely your pressure plate needs to be switched. on my audi it got so bad i would have to pump the clutch like 348563485 times for it to go into gear. when you come to a stop light just pump the clutch like 5 times and it should go into gear easy.
Old 05-23-2011, 02:24 PM   #17
Stickbuilder
Dis gon be gud.
English
Sarcasm
Profanity
Old 06-14-2011, 10:53 PM   #18
raptorman5174
My Ride: 330i ZHP
Im reviving this thread.
This problem is not your clutch, it could in fact be your slave cylinder. Im going through this now to and my mechanic says its the clutch master cylinder that is causing these issues. My slave cylinder wasn't leaking but I replaced it anyway cause my car has 165,000 miles.
But now there is an issue it seems that BMW has an updated part. Furthermore its hard to find and requires some sort of adapter to make it work. I need to research this and see what I find
Sent from my DROIDX using Bimmer App
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 12-12-2012, 04:11 PM   #19
S-trell
My Ride: BMW 330ci coup
Hey I've a question my 330ci 5 speed. My traction controll comes on after I turn the car on along with my brake light how serious is that and what do I do bout that. Oh it is a2001.?
S-trell is offline   Reply With Quote
clutch, gears, help me!, hydrolic, shifting
