Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 08-05-2008, 08:48 PM   #1
steved22
My Ride: 2000 323i
replace inner cones of headlight
I have a 2000 323i sedan. The headlight lamp became loose and was resting on the, low beam, inner silver refective cone. Because of the heat generated by the lamp it melted the cone at the point where you connect the lamp to the cone. I need to replace the cone. From previous DIYs I was able to remove the headlight assembly and then I removed the lens cover. I am not sure how to get the inner cone out. I don't want to force it for fear of breaking something, which I have already done when removing the lens cover. So how do you remove the cones? What is the part name and number of this inner cone? Do the high beam and low beam cones come out separately or as one unit? Can I order just the cone to replace the damaged one or do I have to order the whole headlight assembly? Another question. The rubber weather strips I removed are a little dry. Is there a moisturizer of some sort that I can use to recondition the weather strips? Thanks for the help. This sight is excellent for finding advice on how to repair bimmers.
steved22 is offline   Reply With Quote
Old 10-08-2008, 12:46 AM   #2
bluecougar
A bimmer chick moderator :)
bluecougar's Avatar
My Ride: MB & LR3
||Just another ///M Female Driver||Sold: E46 328ci||E92 335i||E60 M5||
bluecougar is offline   Reply With Quote
Old 01-29-2009, 02:40 AM   #3
lufu
My Ride: E46
having the same problem now...wonder if I can replace the cone or do I need a new headlight assembly
lufu is offline   Reply With Quote
Old 02-17-2009, 02:31 PM   #4
marathonman
My Ride: 325i
same problem here. Any ideas found?
marathonman is offline   Reply With Quote
Old 05-13-2011, 02:28 PM   #5
ZenMonster
My Ride: 01 330XI
Did anyone have a solution to this as i'm experiencing the same issue. Pls chime.. thanks.
ZenMonster is offline   Reply With Quote
Old 05-23-2011, 10:53 PM   #6
rg1bmw
My Ride: 2002 Infiniti Q45
Welcome
2002 BMW 530i
Black Leather/5 Speed/Sport Package
rg1bmw is offline   Reply With Quote
Display Modes
