Sponsored by BimmerWorld
Old 05-24-2011, 08:03 AM   #1
mattlang
My Ride: 2001 330Ci MSport
Car shaking help please - 330ci
Hi,
Looking for some advice please - I have a 2001 330Ci with 116k miles (UK RHD)
When driving at speeds from 65mph - 90mph the car shakes. It's doesn't feel like balancing as it's not felt specifically through the steering wheel and you can visibly see the nearside (Left from driver seat) mirror, passenger seat shake. It is worse in the passenger seat. I have had the front wheels balanced, new tyres and balancing again.
Any thoughts or things to check appreciated!
Matt
mattlang is offline   Reply With Quote
Old 05-25-2011, 07:51 AM   #2
SIX2MIDNIGHT
E46Fanatic
My Ride: 91 E30, 01 325 tour
turn the bass down?
Race German - Premier Automotive Apparel from your Favorite Brands
SIX2MIDNIGHT is offline   Reply With Quote
Old 05-25-2011, 07:52 AM   #3
SIX2MIDNIGHT
E46Fanatic
wheels bearings? bushings wearing out?
Old 05-25-2011, 08:08 AM   #4
mattlang
Bass is turned down - Although that did actually cause the back shelf to vibrate a lot until I'd insulated it.
Front bushes are <12months old rear <36 months. I will visually inspect them at the weekend.
Wheel bearings could be a possibility - can they be DIY checked?
Could a binding rear brake cause this problem?
Old 05-25-2011, 11:18 AM   #5
hummer
My Ride: 2001 330CI
Guibo or drive shaft center bearing. Trailing arm bushings and dragging emergency brake are also possibilities. Struts/shocks are OK?
330, balancing, high speed, shaking, vibration
