Old 05-24-2011, 09:32 AM   #1
Tlvivo
My Ride: 320i Individual
Diff????????
Wassup yall...
i drive 320i steptronic my diff is messed I know nothing about diffs but it started making a knocking sound one day when I was pulling off a robot... Finally got the thing out the car and this is the result:
look inside - teeth are broken - what could cause this?
when i turn this propeller i get the knocking noise
is the last few number my ratio on the diff?
Tlvivo is offline   Reply With Quote
Old 05-24-2011, 11:32 AM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Yep, last numbers are your ratio.
Old 05-24-2011, 12:45 PM   #3
Tlvivo
thanks aggieE46, so when looking for replacement how much does this matter i have had someone offer me 3.38?
Old 05-24-2011, 01:07 PM   #4
Chris-alfonso
My Ride: 330i
A 3.38 is going to make your car accelerate slower and its going to drop your revs when cursing make it a little more fuel efficient.
Chris-alfonso is offline   Reply With Quote
Old 05-24-2011, 01:09 PM   #5
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by Tlvivo View Post
......... how much does this matter i have had someone offer me 3.38?
3.91 to a 3.38 diff is a 13.5% LOSS.
You probably don't want that.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-24-2011, 01:13 PM   #6
Tlvivo
right seems like I am getting the hang of this now - how high can I go after 3.91?
Old 05-26-2011, 08:35 PM   #7
Steven747
My Ride: 05 330ci
wow stock you have a 3.91 thats preety cool
Old 05-27-2011, 06:57 AM   #8
Tlvivo
Hey Steven747 yes, is that unusual?
Old 05-27-2011, 07:05 PM   #9
Steven747
My Ride: 05 330ci
From what I recall I've only heard off diff ratios that high on x3 and 5 autos.. Does it pull kinda hard through first?
Old 05-30-2011, 04:13 AM   #10
Tlvivo
No it doesnt pull hard at all... I enjoy this car, a lot of people get shocked when they find out its a steptronic... because it drives so well...
Old 06-27-2011, 02:50 PM   #11
Tlvivo
guys finding a 3.91 ratio diff is proving pretty tiresome cannot find one anywhere, if i had to get a 3.64 ratio how much loss am i looking at there and what can i gain? Your expert knowledge would be appreciated.
Old 06-27-2011, 03:31 PM   #12
Steven747
My Ride: 05 330ci
Alot better gas mileage
Old 06-27-2011, 03:47 PM   #13
Rob43
Rob43's Avatar
Take a look at this.....
http://www.diffsonline.com/product/gearsets.shtml
Good luck.
Old 06-28-2011, 08:26 AM   #14
Tlvivo
Rob thanks for the link its pretty affordable to get these gear sets even if i have to ship them - how hard is it to replace? Can I DIY or not?
Old 06-28-2011, 01:18 PM   #15
Rob43
Rob43's Avatar
Can't answer, I've never rebuilt a diff. I'm told you need to be Very Precise, If you DIY definitely read up on how to do it.
Good luck.
Old 06-28-2011, 01:59 PM   #16
TxZHP04
My Ride: ESS TS2+ ZHP
Bulding a diff is a bit of an art. I wouldn't normally recommend the average DIY'er attempt it. It is doable though and if you decide to tackle it make sure to do your homework before diving in - it's really easy to ruin a diff if it's not built right.
Old 06-28-2011, 02:24 PM   #17
mrshelley
My Ride: 2004 330i
I can pretty much rebuild anything and have done a fair share of diffs in other cars. For mine, I am willing to spend the bucks to have someone else to do it.
Also, if you are looking at diffs, the Z4 and X3 take the same diff housing. This means they will bolt up into an e46. For example, my diff is from a 2007 Z4 3.0i automatic. For $400 I got a complete 3.73 diff which was better than the $1200 I was getting quoted for just a 3.73 ring and pinion.
Old 06-28-2011, 03:14 PM   #18
Drewfus2101
My Ride: N/A
Good info. I need to do the same thing.
Drewfus2101 is offline   Reply With Quote
Old 07-04-2011, 09:27 AM   #19
Tlvivo
Guys thanks for the info I really learnt a lot here about Diffs, i did not even know much about how these worked!!! I finally fixed the car on friday - I basically spent most of my saturday looking for a diff and much later in the day I was lucky found a very good second hand 3.91 diff for $298!!!!! While repair places where offering to recondition my old one from about $670 - $1200. My car is back on the road doing what it does best...
Old 10-19-2014, 04:15 PM   #20
Tlvivo
Three years and six months and i am replacing yet another diff... My theory, this 3.91 ratio diff wears off too quickly for my style of driving. Thoughts?
diff, differential, driveline
