Old 11-29-2011, 10:29 PM   #101
Hornung418
My Ride: '04 MB ZHP
Stupidity spreads like the plague...
Thanks for some real info, lejeunebimmer.
Hornung418 is offline   Reply With Quote
Old 11-29-2011, 10:31 PM   #102
BROKENBIMMER
My Ride: 328i
Disa changes phlemum size not runner diameter and exhaust has nothing to do with fuel I was referring the the intake on that subject
BROKENBIMMER is offline   Reply With Quote
Old 11-29-2011, 10:33 PM   #103
BROKENBIMMER
My Ride: 328i
According to your perspective on headers by that logic it should run the best with no header or exhaust at all..give that a try n lemme know how it works
Old 11-29-2011, 10:36 PM   #104
BROKENBIMMER
My Ride: 328i
All the mods that this thread brought up would show improvement on a f/I setup. Without a doubt N/A your loseing power moving the powerband up to an unreachabke level for a stock head
Old 11-29-2011, 10:38 PM   #105
Hornung418
My Ride: '04 MB ZHP
What are you talking about?! He's comparing the stock headers to equal length headers. IDK where you learned to read...
Old 11-29-2011, 10:42 PM   #106
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
BROKENBIMMER,
I'm not in an argumentative mood tonight, so I won't argue anything. But since "everything" is hidden under your hood (referring to the nitrous), please write today's date & "BROKENBIMMER" on a piece of paper & take one GOOD photo of it sitting next to your ZEX bottle in your trunk with your smart phone. Then come back inside & upload the photo to E46Fanatics.
If you can't do this Tonight, I, nor anyone else on E46F will ever believe anything you ever say.
Thanks,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 11-29-2011, 10:49 PM   #107
Hornung418
My Ride: '04 MB ZHP
Originally Posted by Rob43 View Post
BROKENBIMMER,
Thanks,
Rob43
+1
Have a read of this POST...You clearly have no idea how a two-stage manifold works and the cross-section differences between the M52TU and M54 runners.
Old 11-29-2011, 10:51 PM   #108
lejeunebimmer
My Ride: 02' M3 SMG, 02' 330i
Ok then I apologize I was lacking some reading comprehension on that one as I thought you were talking about the exhaust side.
It changes the length of the intake runners (I never said diameter). I don't know what you're calling a plenum unless you're referring to the intake mani itself, as what is generally referred to as a plenum is generally a plastic upper intake manifold on most two-piece intake manifolds. (Think Fords, and some GM's.)
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF Splitters
M3 - Not enough room to list
lejeunebimmer is offline   Reply With Quote
Old 11-29-2011, 10:52 PM   #109
lejeunebimmer
The idiot that does it will burn every single exhaust valve.
Its not my perspective either, it fluid and thermodynamics.
Old 11-29-2011, 10:52 PM   #110
BROKENBIMMER
My Ride: 328i
I've said multiple times idc if anyone believes me..my orginal post that brought up this pissing match was what power my car made 3 days after I bought it..completely stock...how it lead to what is done to my car now I dnt know..
Old 11-29-2011, 11:01 PM   #111
Rob43
Rob43's Avatar
Since you only have about 50 plus posts, you could change your name to "FIXEDBIMMER" & nobody would know better. A fresh start.....might just be the ticket for you.
Good luck.
PS. Where's that pic. ?
Old 11-29-2011, 11:03 PM   #112
Hornung418
My Ride: '04 MB ZHP
Because your numbers are complete BS! How can you not realize this?
A ZHP has 235 est at the crank. Dynos show an average of 205 whp. Difference of 30 hp.
How does a stock, 13 year old 328i, that made maybe 193 at the crank brand new, dyno 10 horsepower less at the wheels? Your numbers are not accurate at all. The only purpose it would serve is as a tuning tool. You're as dense as they come.
Old 11-29-2011, 11:09 PM   #113
BROKENBIMMER
My Ride: 328i
Why would I go to the trouble of hideing everything to have a bottle sitting in my trunk..that would make alot of sence huh..and I dnt post becuz I dnt have to ask the world how to check my oil..I only post to buy n sell parts n correct people talking bullshit..but I'm done with this lesson..if you would like to continue your education I'll start a class..I'll even take you all in free if charge..make a nice tax write off teaching the less fortunate
Old 11-29-2011, 11:15 PM   #114
lejeunebimmer
I'll stick to what I've learned from working in shops, my physics and engineering classes, from the real Master Techs that I have worked under, and from reputable racers and engine builders. Thanks for the offer though.
Old 11-29-2011, 11:26 PM   #115
SK330ci
My Ride: 02 330ci w/ 3 Pedals
BROKEN
you're really 14 years old, aren't you.
I'm with all the rest, no pics.....because it does not exist.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 11-29-2011, 11:27 PM   #116
Hornung418
My Ride: '04 MB ZHP
If you want to teach us a lesson from your bullshit encyclopedia, create your own thread.
Seems like you're getting frustrated and losing your ability to write coherent statements. Vote for new name to be GRADUALDOUCHEBAG...Seems educated at first then starts break down to real life behavior.
Old 11-30-2011, 01:21 AM   #117
ZHud3
My Ride: black 323Ci
2000 323Ci
1992 325is Sold ):
1984 325e
ZHud3 is offline   Reply With Quote
Old 11-30-2011, 08:11 AM   #118
jared_wiesner
My Ride: 1999 328i (M54b30)
I've tried to explain this to you already. The problem with this approach is that you would lose the extra velocity built into having exhaust exit tubes (scavenging effect). Not to mention the pulse tuning gained by proper engineering and design of premium grade headers (not claiming this is what you get with ebay). Also as mentioned before, after shut down, the cold air rushing into the engine with no heat buffer built up in the exhaust manifold would not be benefitial to your valve's health
The velocity of exhaust gasses is key. Not back pressure.
jared_wiesner is offline   Reply With Quote
Old 11-30-2011, 11:14 AM   #119
Iceman00
Banned User
My Ride: E90 6MT
You know, I think you guys are being a little hard on this guy. He actually has a basic grasp on how an engine works. Verdict is still out on his credibility though.
Old 11-30-2011, 11:31 AM   #120
jared_wiesner
I agree, there is no need for name calling. I take more issue with the claims being made, it dilutes and pollutes the knowledge base these forums provide.
I would still like if you could explain how what I have said is incorrect. I would like to present accurate information the same as I expect it from others.
