Old 05-27-2011, 08:24 AM   #1
Ran035
My Ride: 325xi wagon
Painting Steering Wheel Cover
You can make your steering wheel cover look like new, just re-paint it. The paint I used was TAMIYA COLOR for Plastic. The color was Matt Black TS-6. You can wet sand with 500 or 600 grit sandpaper to feather in the bad areas.
I hope this helps.
Ran035 is offline   Reply With Quote
Old 05-27-2011, 10:45 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yup yup, this has been done for a while.
Old 05-30-2011, 08:29 AM   #3
bodomchild
My Ride: E46
And how do you remove steering wheel cover for painting?
Anyone do this job?
bodomchild is offline   Reply With Quote
Old 05-30-2011, 02:48 PM   #4
Ran035
You need to diconnect the battery, Remove the Air Bag. 2 Torx screws at the bottom of the cover, I think there a # 15.
Old 05-30-2011, 02:50 PM   #5
DANe46
My Ride: 2004 BMW 325i E46
pictures?
DANe46 is offline   Reply With Quote
Old 05-30-2011, 02:51 PM   #6
WheyArea
My Ride: '03 TiAg ///M3
What he said ^^
You'll need two skinny flat head to punch inside the wheel and pinch the 2 large safety pins. Then inside I believe there are 2 Phillips head screws IIRC
Great DIY found here: http://www.my330i.com/mod23.php (just follow until you remove the trim)
/// Dinan ECU /// Brembo BBK /// BBS LM 19" /// Bilstein PSS10
/// Eisenmann Exhaust /// Supersprint Mid Pip /// AC Schnitzer Spoiler
/// Hamann Lip /// AC Schnitzer CF Diffuser /// K&N CAI /// Valentine 1
Coming Soon...... OEM SSK, CSL bootlid
WheyArea is offline   Reply With Quote
Old 05-30-2011, 02:53 PM   #7
WheyArea
Originally Posted by DANe46 View Post
pictures?
Old 05-31-2011, 02:16 PM   #8
DANe46
I meant pictures of the wheel, before/after paint
Old 05-31-2011, 05:27 PM   #9
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
Other alternatives can be 3M Di-Noc wrap perhaps.
Found this image here at:
http://www.bimmerforums.co.uk/forum/...riolet-t69248/
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 05-31-2011, 07:09 PM   #10
Ran035
Painted Steering Wheel
Heres a photo of the painted steering wheel. Before white plastic showed at the bottom and top sides of the lower cover.
Old 02-04-2012, 10:33 PM   #11
dah328
My Ride: 330i ZHP & E46 325i
I just finished doing this on my car (along with a Coby Wheel re-wrapped steering wheel and shift boot -- very nice) and I'm having a lot of trouble getting the airbag seated properly back in the center of the wheel. It sticks out about 1/4 inch past the face of the wheel and I'm sure it wasn't like that before. Is there some trick to getting it to seat all the way in?
Edit: It turns out I didn't have the airbag bracket assembly properly seated. Once I fixed that, it went in pretty easily.
dah328 is offline   Reply With Quote
