Sponsored by BimmerWorld
Old 05-29-2011, 09:25 PM   #1
ZHud3
My Ride: black 323Ci
slotted vs drilled
im upgrading to 330 calipers and rotors on my 323. I see drilled, slotted, and drilled and slotted rotors. WTF do they do and which will better suit me. i use this car as a daily driver and im looking for just a little performance upgrade. Any suggestions?
ZHud3 is offline   Reply With Quote
Old 05-29-2011, 09:59 PM   #2
Steven747
My Ride: 05 330ci
yeah use the search bar
/thread
Old 05-29-2011, 10:01 PM   #3
ANREC330
My Ride: C6 Vette & M3
only gain you'll see is due to getting bigger rotors, and if you'd search you would find everything you need
ANREC330 is offline   Reply With Quote
Old 05-30-2011, 08:24 PM   #4
BMW_Matt
My Ride: 135
Blanks + better pads
BMW_Matt is offline   Reply With Quote
Old 05-30-2011, 11:14 PM   #5
TerraPhantm
My Ride: M3 & ZHP
The only drilled rotors I'd run in stock 330 fitment are the BMW Motorsport rotors - only because they're a decent bit lighter and have directional cooling vanes. Otherwise I'd just run blanks... Maybe slotted if I wanted something that looked a little cooler.
Old 06-06-2011, 08:08 AM   #6
SPDSKTR
My Ride: E46 ZHP TS2+ Coupe
I'm using Zimmerman cross-drilled. They look good, but the holes are fairly small and there aren't that many of them. Stopping power is about the same as before. For $80 a rotor, it wasn't that bad of a deal.
Originally Posted by Brucifer325 View Post
Thread sucks so bad they moved it to the Feedback Forum.
SPDSKTR is offline   Reply With Quote
Old 06-06-2011, 11:39 AM   #7
Steven747
My Ride: 05 330ci
mine have a good amount of holess
Old 06-06-2011, 03:03 PM   #8
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Holes are good !
SUMMIT POINT WV 1:24:229 SCCA
Old 06-06-2011, 05:19 PM   #9
someguy_99
someguy_99's Avatar
My Ride: E46,335Xi,Lambo,...
mo holes mo problems , slotted but do ur research
someguy_99 is offline   Reply With Quote
Old 06-06-2011, 08:04 PM   #10
Steven747
My Ride: 05 330ci
wrong
Old 06-10-2011, 10:48 PM   #11
Shakewell
My Ride: 2004 325i Sedan
Thats why high end cars and Sport bikes come from the factory with drilled rotors??
USMC - Aircraft Recovery - MCAS Miramar
Shakewell is offline   Reply With Quote
Old 06-10-2011, 11:02 PM   #12
TrickTizzle
My Ride: 325i
Just because they are factory doesn't make them good.
Do your research.
Old 06-10-2011, 11:31 PM   #13
Pierce1
My Ride: 03 330xi
Those OEM rotors have cast holes not drilled. Drilled holes will get cracks around the holes over time with high temperature use ie tracking. It's a metalurgical thing.
Pierce1 is offline   Reply With Quote
Old 06-11-2011, 10:05 AM   #14
jpr
My Ride: '99 323i
Incorrect.
To find out more, follow this excellent advice:
/thread
jpr is offline   Reply With Quote
Old 06-11-2011, 11:00 AM   #15
mko9
My Ride: '04 330i ZHP
1. OEM rotors are drilled, not cast, just like all other cross drilled rotors
2. I am not aware of any modern race series that uses cross drilled rotors, which should tell you something about any real benefit.
Mike
'04 BMW 330i ZHP
'11 BMW 535i
'13 Land Rover LR4
mko9 is offline   Reply With Quote
Old 06-11-2011, 01:31 PM   #16
Pierce1
My Ride: 03 330xi
Ok, how about this. Not all rotors with holes in them are drilled. The higher quality ones are cast. Drilling causes stress cracks to form around the holes over time under high temp use. Casting the rotors with holes reduces the formation of these stress cracks. Personally I would never bother spending the money for such rotors. They are simply not necessary.
Old 06-11-2011, 02:10 PM   #17
jpr
My Ride: '99 323i
Still doesn't work.
All rotors with holes in them are in fact drilled. Perhaps it that is not the case for some exotic materials like carbon-ceramic that cost more per rotor than your entire car, but it is true for any rotor you can actually buy.
Old 06-11-2011, 02:30 PM   #18
Mulatto325
My Ride: 325ci convertible
I think cross drilled rotors look good. If you get a real company like stoptech like me or brembo and you will be fine.
And there less expensive then oem.
Good set of low dust pads and some ss lines your stopping power will be the same or better then stock for less money. Oh yea and they look cool. Also 95% less brake dust.
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 06-11-2011, 07:29 PM   #19
Chris__B
My Ride: Several
Originally Posted by jpr View Post
Still doesn't work.
You are more correct than you think. Carbon-ceramic rotors have holes drilled in them as well, which are done before final siliconization. There are no cases anywhere of "cast in holes". It is just another Internet myth.
Drilled holes are very useful in increasing initial pad bite at high speeds, improving wet performance and can provide slightly better cooling at elevated temperatures. HOWEVER, most drilled rotors sold into the aftermarket are poorly engineered, use low-quality castings, improper hole patterns and sub-standard finishing techniques. This has contributed to the reputation that drilled rotors crack too soon or have other problems.
Bottom line: If you are going to go with drilled rotors (which are fine for the street and very light track use), then don't skimp with the eBay, Chinese crap. Buy the good stuff! Disclaimer: Drilled rotors are not for heavy track use. Use slotted-only or, even better, J-Hook rotors instead.
Chris
Chris__B is offline   Reply With Quote
Old 06-11-2011, 07:54 PM   #20
Steven747
My Ride: 05 330ci
ive used my drilled zimmermans at the pad twice and i wasent going easy. zero problems what do you say to that?
330, brakes, drilled, rotors, slotted
