Old 06-29-2012, 11:21 PM   #1
Marlow.bailey
My Ride: Bmw 323ci
Battery completely dead after fan running when car engine is off
After driving home in my 2000 323ci I'm 100degree weather. When I get home the fan was still running after I turned the engine off. I didnt think anything of it becuz it was very hot out and I had the AC on the way home. I wanted a few hours and went back out to check the car and the fan was still running. When I tried to turn the car on, it started but took a sec more than usually to turn over. So I turned it off tired it again and I get the click click click. At the point the fan is still on. The horn didn't blow as strong and the radio didn't come on. Check the car later and it's no power at all. Could this be a simply replacement of the battery or something more. What would cause the fan not to turn off and would this drain the battery. HELPPPPP
Marlow.bailey is offline   Reply With Quote
Old 06-29-2012, 11:29 PM   #2
M3JetBlack
My Ride: 2002 M3
Yes it would drain the battery. Your car wont start if the battery doesn't have enough juice. Nothing will work or be as strong if the battery is low.
But i dont know why the fan is still running...
2002 JetBlack ///M3
CCW Wheels / GC coilovers / Alcon / Eisenmann / SuperSprint / Vorsteiner / HPF Stage 2
Instagram: @somuchcalitis
M3JetBlack is offline   Reply With Quote
Old 06-29-2012, 11:29 PM   #3
tcphoto
My Ride: E92 335 MT Coupe
Check the FSR, I had the same issue. I was lucky enough to have a rather new battery and they replaced it after testing and I installed a new FSR which was the actual problem.
tcphoto is offline   Reply With Quote
Old 06-29-2012, 11:30 PM   #4
Marlow.bailey
My Ride: Bmw 323ci
What's a FSR
Old 06-29-2012, 11:30 PM   #5
fiveightandten
My Ride: '03 330ci / '98 M3
The fan is only supposed to run for up to 10 minutes, and the ECM should know the battery voltage and not let it run the battery down. It's odd that it ran the battery down. But it's possible that this is a combination of an older weak battery and a cooling system issue.
It could be getting false input from the coolant temp sensor. Does the car have any codes?
If it were me, i'd replace the coolant temp sensor and try again. It's cheap and easy to replace and could be the culprit. Be quick and you won't loose much coolant. Bleed the cooling system afterwords.
How old is the battery?
-Nick
fiveightandten is offline   Reply With Quote
Old 06-29-2012, 11:33 PM   #6
Marlow.bailey
My Ride: Bmw 323ci
No codes at all at least no lights on the dash... The battery is about 4.5yrs old..... I was thinking the battery was to weak to send a signal to the fan to turn it off. Is that even possible.
Old 06-30-2012, 12:18 AM   #7
MercForHire
My Ride: M235i 6MT
Its about time anyway for new battery.
Old 06-30-2012, 07:42 AM   #8
Marlow.bailey
My Ride: Bmw 323ci
Hopefully that's all it is
Old 06-30-2012, 09:24 AM   #9
tcphoto
What's a FSR
That is what the search function is for.
Old 06-30-2012, 09:29 AM   #10
Marlow.bailey
My Ride: Bmw 323ci
No need to be an ass Thanx tho it was the battery car is running fine
