Old 05-30-2011, 09:58 PM   #1
myothercarisatruck
My Ride: 325i
Auto Zone codes came up volkswagen???
Went to Auto Zone to check the service engine soon codes and it cam up as volkswagen. Is this normal or did they screw up.
Didn't give me a code per se, but said air injection system insufficient flow.
Probable cause is faulty air solenoid valve and faulty air system relay.
Is this an O2 sensor? If not, where are they located?
Thanks in advance...
If you're gonna be stupid, you better be able to handle the consequences...
myothercarisatruck is offline   Reply With Quote
Old 05-30-2011, 10:04 PM   #2
ALPIN3
My Ride: E46 M3 & E46 323i
Does your engine look like this?
But on another note, what were the PXXX codes that were pulled when scanned?
ALPIN3 is offline   Reply With Quote
Old 05-30-2011, 10:09 PM   #3
HardPark'd TT
My Ride: is parked hard.
Send a message via AIM to HardPark'd TT
Must have been a mix up in the assembly line in Mexico
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
HardPark'd TT is offline   Reply With Quote
Old 05-30-2011, 10:10 PM   #4
GuitarmanTT
My Ride: 1999, E46 328i
Auto zone coder is retarded Could be the pump, check valve (back of motor) or air valve (next to pump) There is a diy on you tube on how to tell which it is. Search ( e46 secondary air system ) on youtube.
http://www.realoem.com/bmw/showparts...03&hg=11&fg=45
http://www.realoem.com/bmw/showparts...88&hg=11&fg=50
http://desmond.imageshack.us/Himg231/scaled.php?server=231&filename=img20110608111530.jpg&res=medium
GuitarmanTT is offline   Reply With Quote
Old 05-30-2011, 10:19 PM   #5
Zell
Zell's Avatar
My Ride: so turbo wow
Yep, you got jipped. You've been driving a vdub this whole time.
Old 05-30-2011, 10:20 PM   #6
HardPark'd TT
That explains the CEL
Old 05-30-2011, 10:32 PM   #7
myothercarisatruck
My Ride: 325i
LOL, no it actually looks like this...
Old 05-30-2011, 10:33 PM   #8
myothercarisatruck
My Ride: 325i
That's the thing... There were no codes... Just Definition and Explanation...
Old 05-30-2011, 10:34 PM   #9
N89
My Ride: 330Ci
You obviously haven't done any research...
N89 is offline   Reply With Quote
Old 05-30-2011, 10:36 PM   #10
olinjohnston
My Ride: Dakar330Xi + 840 6MT
Send a message via AIM to olinjohnston
Oh I know what the problem is...
You went to AutoZone for diagnostic work. What works for a 98 Corolla isn't always gonna do it for a modern BMW.
olinjohnston is offline   Reply With Quote
Old 05-30-2011, 10:38 PM   #11
myothercarisatruck
My Ride: 325i
Actually, the research that I have done is google for these probable causes and they come up for jetta's, audi, and passat. What are you referring to?
Old 05-30-2011, 10:44 PM   #12
myothercarisatruck
My Ride: 325i
Yes I did, but because I live in a very small town in Tennessee, and we have no import shop in town that owns a diagnostic machine with BMW software. Closest one is about 40 miles... I guess I will make the trip next week... I saw on here that Auto Zone could check it, but wanted to check with you guys as this sounded rather strange to me... I grew up around American muscle cars and this is new to me... It used to be a frame, body, engine, suspension, and transmission, and a very small wiring harness for lights and an am radio... Now it's a computer fo everything, code this, sensor that... It's new to me so I appreciate the help!
Old 05-30-2011, 10:48 PM   #13
Blocked Out
My Ride: Imola 330i M-Sport
You can have a free obd 2 scanner on your smart phone for free. I mean its 2011, isnt it. No need to drive anywhere.
If you want something a little bit more accurate and with a bit more potential , you can buy a diagnostic software. Some run as low as $40 and will do the job JUST fine. No need to drive to auto zone.
Original BMW Teile ///
IMG_1725
Old 05-30-2011, 10:50 PM   #14
myothercarisatruck
My Ride: 325i
Blacked out... Is that an I phone app?
Old 05-30-2011, 11:05 PM   #15
Blocked Out
Originally Posted by myothercarisatruck View Post
Blocked out... Is that an I phone app?
They have many apps , for iphones, androids. I have a few on my X10 Sony Ericsson. They work just fine. Will read OBD2 codes via wifi or something. Tells you what the code is, then you have a list that tells what the code means.
I tried them but dont use them, they;re just like a fun joke to me eventhou they work just fine, I like to use real diagnostic software.
IMG_1725
Old 05-30-2011, 11:13 PM   #16
myothercarisatruck
My Ride: 325i
Thanks for the heads up... I figured it would be similar to the tracking anyones phone ap... Hey, give me your number while you are standing beside me and I can put it in my phone and show you exactly where you are on google maps!!!!
Old 05-30-2011, 11:52 PM   #17
TerraPhantm
My Ride: M3 & ZHP
The OBDII spec has a bunch of universal codes, and then a set of numbers that are reserved for manufacturer specific codes (P1XXX).
With the manufacturer specific codes, the autozone scanners only store a few brands... In the case of whatever code you were throwing, they only knew the VW definitions I guess. I remember I once got some code reads and the only data they had for those numbers were from Suzuki or something like that.
Anyway, if the printout has the code somewhere on it (should be P1XXX or something like that), post it here and someone probably has a table with the BMW definition of that code. Or you can google it.
