#1 |
Fixed my airbag light today
Yeah, you guessed it: my airbag light came on. Ordered the Peake tool because I'm sick of the thing going on and having to pay someone to read the code.
Sure enough, code was 03/02: driver's side seat belt tensioner. e46fanatics to the rescue. I used the search bar ( Read through a bit more and figured I'd either have to do the BMW documented solution of splicing around the harness, or replace the tensioner. My money was on the tensioner so I ordered one. Anyway, today was repair day. Pulled the seat out and cut away the old wiring connector to the tensioner. Then I realized that some mechanic long ago had already applied the harness splice. That's why my connector had two wires cut off it. Had to haul out the soldering iron and shrink tubing to reconnect the two wires I'd chopped off during seat removal thing they were old and unneeded I have to say, whoever did the original repair did a crap job. Electrical tape everywhere instead of proper shrink tubing.After that little mix-up I swapped in the new tensioner, stuck everything back together, cleared the code, and voila. No more airbag light. If anyone in the Seattle area ever needs their code read let me know. I have the Peake tool now. Neil |
#2 |
I need to fix my passenger side....
Is there a tutorial?? I'm scared if the airbag pops in my face |
#3 |
crap, I may have done the same thing the other day when I pulled my driver's seat to install my dice silverline. I now have an airbag light on. damn it.
#4 |
my airbag is on too, would it matter if it was on or not, its not like the airbag wont deploy if the light were on, right?
#5 |
From what I've read, it won't deploy if the light is on.
#6 |
before you start working just disconnect the battery and you're safe.
![]() I code cars-p'm me |
#7 |
You don't need to unplug the battery or be afraid of it deloying unless your really trying to set it off.
Sent from my MB860 using Bimmer App |
#8 |
Mine is on the passenger seat, and only if someone is sitting in the seat...
If you're gonna be stupid, you better be able to handle the consequences...
#9 |
splicing airbag wires is a huge no no. It calls for the entire harness to be replaced.
#10 | |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
They have a decent-sized capacitor bank that holds a charge, designed so that in case your battery gets disconnected for some reason while driving, you will still have airbags for an ample amount of time. Any time you work with the airbag you should do this unless it is absolutely required to have the battery on to adjust something. Last edited by Zell; 05-31-2011 at 09:47 AM. |
#11 | |
Neil |
#12 | |
Before doing the tensioner though you need to check and see if you have the BMW repair kit that re-routes the tensioner wires out of the wiring harness. If not, do that first since it's cheaper and more likely the cause. Neil |
#13 |
move the seat all the way to the front unbolt two bolts
move the seat all the way to the back unbolt two bolts disconnect battery, wait 10 mins disconnect all the plugs take the seat out of the car...
#14 |
One thing I'll add to the steps: make sure to lift the seat height up a bit from total bottom, otherwise when you go to run wires you won't be able to fit the connectors through the seat frame. I had to stick my seat back in the car in the middle and plug it in just to lift the seat 1/2 an inch. Sigh.
Neil |
#15 |
My airbag light was on last week, had my indy mechanic doing some other work and he reset it, but now it's back on again (ugh). Wondering if I need to bother with it again. Would think that BMW would cover this since it's a safety issue and the low miles I have (67K)?
#16 |
Yes, you should bother with it, since if it's on the airbag won't fire
![]() Neil |
