Old 05-31-2011, 12:18 PM   #1
Flycaster
My Ride: '05 Z4 2.5, '13 ATS
OBC's MPG not working, worth fixing?--Solved
The MPG indicator on the OBC of my 2002 325 has been stuck at 21.1 for about a week or two. All other functions work. It has been reset to Zero, but comes back to 21.1 mpg.
Is there an easy fix or does the total computer have to be reset?
EDIT:
Wife thought that resetting the mileage was same as resetting the OBC's MPG. I reset the MPG, and it seems to be working now.
Flycaster is offline   Reply With Quote
Old 05-31-2011, 12:22 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
Does it go back to 21.1 right away after you zero it?
Old 05-31-2011, 12:30 PM   #3
Flycaster
Don't know. This is what wife said. in a couple of hours I'll be able to test it myself and then report back.
Old 05-31-2011, 12:47 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Disconnect the battery for five min and see if it does anything.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 05-31-2011, 01:52 PM   #5
jdstrickland
My Ride: '94 325iC & '00 323i
Stuck? What if you're getting 21.1 mpg? Then it's reporting correctly, and is not stuck at all.
Old 05-31-2011, 02:14 PM   #6
CylonRed
My Ride: '01 E46 330i sport
http://forum.e46fanatics.com/showthread.php?t=847683
CylonRed is offline   Reply With Quote
