E46 Xi Forum
The E46 XI was produced from 01-05 in sedan and touring body styles. Powered by either a 2.5L inline 6 in the 325xi or a 3.0L inline 6 330xi. Discuss all thing about BMW AWD E46 'Xi' here. |
#1 |
Tires for 8.5" rim
For my stock height 325XI:
I'm picking up some TRMotorsports C2 17x8.5's and I'm trying to figure out the best tire size. I'm looking at 225/45/17, 245/40/17, and 255/40/17. The overall diameter of the 255/40/17 seems to be closest to stock but I'm not sure if 255 will rub. I know 225's will fit fine but I'm not a fan of the stretched look and I don't know how stretched (if at all) a 225 would be on an 8.5" rim. Any thoughts? I searched but couldn't find anything relevant to my sizes and the XI's. |
#2 |
Searched some more, seems 255 fits fine on the back. Will they fit the front fine also?
EDIT: Just ordered 245/40/17. Last edited by xtascox; 05-31-2011 at 01:38 PM. |
#3 |
I would have gone with a 235 width. What are the offsets of the wheels? What brand/model tires?
I probably couldn't fit a 245/40/18 with ET38 up front, depending on brand/model. I have 235/40/18 star specs and there's maybe 5mm between the tire and strut. |
#4 | |
Hankook Ventus V4 |
#5 |
^It's gonna be close! I'm not sure how wide the hankooks are. May need spacers up there.
#6 |
#7 |
#8 |
My Ride: 2009 328i xdrive
yea 5mm spacers would be required up front.
![]() 2009 MBM | ZPP | ZSP | ZCW | CA | 6FL | NAV | XENONS | 18x8.5 VB3s ET30/25 |
#9 |
Well we'll find out. The shop I ordered from said he researched it and that they would fit so it's on him if they don't. Thanks guys.
#10 |
Would 5mm spacers work with stock lugs?
Does the XI front have less clearance than non-XI? I talked to a member on here with the same wheels and 255/40-17's and he had no clearance issues on stock sport suspension. Given the XI sits higher that a non-sport non-xi, wouldn't one guess they should clear no problem. Last edited by xtascox; 06-01-2011 at 12:52 PM. |
#11 |
Just thought I'd update and tell you guys that everything fit no problem. 245/40-17 on TRMotorsports C2's.
#12 |
Good to know! Thanks for updating the thread with the results. Im thinking of going to a 245 next on my 18s, i think with an 18 id need spacers though with an et40
#13 |
^dunno if 17 vs. 18 will make a difference.
A lot has to do with the tire brand/model. Not all 245 tires would fit with ET40 wheels. |
#14 |
#15 |
huh? did they mount it centered on the rim?
#16 |
