Engine & Performance
Everything to make your car faster! Air intakes, superchargers, turbos, flywheel & clutch, differentials, chips, short shift kits, exhausts, etc..... |
#1 |
FS: Active Autowerke Used E46 323i/325i Supercharger Kit
This is now on ebay, Item number: 150639234956
I have a used Rotrex C30 kit for the E46 323i or 325i. - The kit is complete except for the software which is available from AA. - Also the S/C unit needs to be rebuilt. It was making noise before it was taken off. superchargerrebuild.com can help with that for a very fair price. I didn't opt to do it myself that way the new owner can choose standard vs ceramic bearings and also have the warranty under his name. - I might also be missing a few vacuum lines but the main hardware and parts are there. I also have the instructions in a pdf file. Considering what this retails for, Im asking PRICE LOWERED TO $1100 plus $75 shipping. This is what AA has to say about the kit: It's a lot like having an M3. Without the M3. With 8 pounds of boost for an increase of over 100 flywheel HP, Active Autowerke's 325i and 323i super¬charger systems deliver instantaneous power and low end torque in amounts far beyond what the bimmer factory gods intended. Specifically designed to run with 91-93 octane pump fuel and your stock engine management system, this system uses our dyno-tuned software adjustments to manage ignition, fuel, vanos, rev limits, speed governors, etc - all programmed into the same onboard computer your car was born with. So the performance mutation from normal to 'extra-assertive' is smooth and dependable, and totally reversible to stock. Even our oil cooling upgrade is self contained and non-intrusive of the factory oil system. Bottom line: you get to experience near-M3 performance in your 325i or 323i at an incredibly affordable price. Without sacrificing drivability, comfort, integrity or amenities. Not too shabby at all. Key Features Rotrex C30-94 trim supercharger 8 psi boost level CNC machined supercharger bracket with hardware Front-mounted air-to-air intercooler Self-contained oil system with front-mount oil cooler 6 higher flowing fuel Injectors Active Autowerke/Bosch bypass valve High temperature silicone hoses with stainless clamps All mandrel bent tubing for improved flow K&N air filter Active Autowerke Dyno-Tuned Software All mounting hardware, plumbing, hoses and clamps Illustrated instruction manual & installation guide Performance Specs Power : 310 BHP @ 6800 rpm Torque : 266 ft-lbs@ 5800 rpm Boost Level : 8.0 psi ![]() Last edited by Zubehor; 07-29-2011 at 12:00 PM. |
#2 |
Would you ship to Argentina? do you know were to get Euro ECU maps for this kit? how much time did you use it? is repairing it mandatory? please explain further, im interested. could you calculate shipping? thank you!
#3 |
Dibs also in the us.
#4 |
JM Fangio, let me check on the shipping I have a feeling it's going to be pricey. Any suggestions on who to go with? Probably USPS will be cheaper then UPS or FedEx.
halik007, sent you a pm back. |
#5 |
Could you provide me with a quote shipped to 97305 (Oregon) please?
#6 |
DK Jack Sparrow
My Ride: 328Ci | Range Rover
Wish I could have my shop look this kit over an give me an estimate how much I will have to put into this to get it running
![]() Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244 Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI ![]() |
#7 |
its priced so cheap its worth the risk if there was any but like i said you need the get the main unit rebuilt and get a tune.
#8 |
DK Jack Sparrow
Dude, the parts need to be rebuilt, who knows what additional parts would be needed to fit it on a 328, and if somethings totalled, it's a big bullet to bite. If you were local, I would take it to my shop and have them look it over to give me a round idea what will be needed to get it back in perfect working order.. as it stands, too much money to take a risk like this.... for me anyway
#9 |
Dude, the s/c unit needs a rebuilt which is the only part thats a wear item. The rest are brackets and piping pretty simple concept, but OK i understand its not the kit for you.
#10 |
true with a sued kit id probobly just get the bearing rebuilt anyway for security noting how much you saved buying it used but this is like a 4th of the price and how much coul it possibly cost to get the bearing rebuilt? no more than 400. so it s a win win
#11 |
Hello! Im interested. I will by for 1100. pls, pm me or e-mail me ( diabolus@inbox.ru )
#12 |
your sig says CA, but on ebay Chi? Im confused where you are located. Thanks.
#13 |
I recently relocated and didn't update my info in the sig. The kit seems to have sold on ebay, I will update the thread if its still available.
