Old 06-04-2011, 04:53 PM   #1
BMWQUEEN01
My Ride: 01 325i
Fixing Codes on my car! Need your input!
So...I have 3 codes on my 01 325i 346:
18- Exhaust Cam Pos Sensor
239- Misfire cyl 2
48- torque converter clutch slip
Trying to see what I should do first or what is causing these to malfunction. Researching the Torque Converter Clutch to see what that is exactly. Any input you guys may have would help me tons! My car is still drive-able but trying to get it fixed ASAP before it gets worse. I'm thinking to go ahead and put on a new cam sensor, but not where I should start.
BMWQUEEN01 is offline   Reply With Quote
Old 06-06-2011, 09:14 AM   #2
BMWQUEEN01
My Ride: 01 325i
Any suggestions would be great!! Thanks!
Old 06-07-2011, 06:55 PM   #3
e46crooser
My Ride: 99 328 5spd
how many miles are on your car? Has trans been serviced? Usually a code 48 indicates a transmission going south but you never know. Is the car running rough? If only one cylinder misfire is indicated usually it's a bad ignition coil. As far as the cam sensor code goes, I'd replace intake and exhaust cam sensors (Use genuine BMW sensors) and the o-rings as well. I've tired the Febi sensors and believe me you're not doing yourself any favors b/c you'll be doing the job again in like a week. HTH
e46crooser is offline   Reply With Quote
