Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 06-06-2011, 06:38 AM   #1
krzyc
My Ride: 2000 323ci/2002 M3
Code P1542, EML Lights comes on!!!
Wow i just cant catch a break . Suddenly my car is throwing the p1542 code and the EML light is comming on an of course sending the car to limp mode. Not to sure what exactly this code means. Any takers.
krzyc is offline   Reply With Quote
Old 06-06-2011, 06:46 AM   #2
Scott87
My Ride: 325ci 2001
Throttle Actuation Potentiometer Range/Performance
Something to do with the drive by wire system? Had any work done recently?
Scott87 is offline   Reply With Quote
Old 06-06-2011, 06:57 AM   #3
krzyc
Im pretty sure mine is a cable system. I noticed a cable there before when cleaning my ICV. It seems to always fail when sitting in traffic, which is the worst place for `limp mode`to occur!
Old 06-06-2011, 07:16 AM   #4
shanneba
My Ride: 2003 330Ci
Even though you have a throttle cable, the ECM still controls the actual throttle opening
Take a look at this document, pages 51-54 -
http://www.beisansystems.com/misc/SE...ROL_SYSTEM.pdf
The new engine throttle valve (MDK) differs from the familiar EML in the following points:
The accelerator pedal potentiometer (PWG) is now integrated in the MDK housing.
A throttle cable is used to actuate the throttle potentiometers and also serves as a backup
to open the throttle plate (full control) if the MDK system is in fail-safe.
Join BMWCCA
Old 06-06-2011, 10:05 AM   #5
krzyc
Yes you are right I called BMW and the service guy explained how the system works and that even tho there is a cable it is still a wire signal that operates it.
So my next question is, what can I do in the mean time to trouble shoot this problem. I would rather not spend all kinds of money at the dealer ship when I could simply buy the need part and install it myself. I understand that BMW`s reader system could pin point the problem, however it seems to me the main problem is the throttle body its self.
Old 06-06-2011, 10:31 AM   #6
shanneba
My Ride: 2003 330Ci
You might check is the connection to the throttle body, make sure the wiring and contacts are good and the connection is twisted on completely.
You could check the throttle body and make sure there isn't any build up on the body or butterfly that might cause it to stick.
http://tis.spaghetticoder.org/s/view.pl?1/04/35/75
You might also check the throttle pedal clearance - make sure the cable moves freely.
http://tis.spaghetticoder.org/s/view.pl?1/04/43/52
Join BMWCCA
Old 06-06-2011, 01:10 PM   #7
krzyc
Its so strange how it will run fine for like an hour and then suddenly just quit. And then other times it will consistently turn on and off. There is no pattern, just random malfunction. And almost always as soon as i hit a stop light or slow moving traffic.
Old 12-04-2011, 08:47 AM   #8
BMW_525i_noob
My Ride: E46 323ci
Did you find a fix... same problem here
BMW_525i_noob is offline   Reply With Quote
Old 12-05-2011, 08:30 AM   #9
krzyc
I put another throttle body in, second hand from ebay. Hasnt come back since.
Old 12-06-2011, 11:26 PM   #10
e46Sushi
My Ride: '99 323i 01' 525i
My car already has a new throttle body installed. I'm manged to temporarily fix it by cleaning the ICV. I drove it to work and it didnt make it back home. I'm ordering a new ICV to fix the problem.
Info on my car:
I have a 1999 323i (155k Miles) and my car has a Mechincal Style Pedal with no sensor.
Replacing the the thorttle body alone did not clear the issue for my vehicle.
For anyone else that runs into this problem.
e46Sushi is offline   Reply With Quote
Old 12-07-2011, 12:12 AM   #11
shanneba
My Ride: 2003 330Ci
Where the adaptations cleared (in the DME) after the throttle body was replaced?
Note:
A faulty throttle adjusts the adaptation values stored in the DME control unit. These adaptation values must be reset after the throttle assembly has been replaced.
Clearing adaptation values:
- Connect DIS Tester
- Select vehicle type
- Select "DME Motor Electronics MS42", ne carry out individual brief test
- Continue with bottom right arrow
- The "Fault pattern selection" window appears.
Select "Function selection" (bottom left)
- The "Function and component selection" window appears:
- Select "Service functions"
- Select "Drive"
- Select "Digital Motor Electronics"
- Select "Reset adaptations"
- Select "Test schedule" (bottom left)
- The "Test schedule" window appears. ne Select "Reset adaptations"
For subsequent procedure, follow DIS instructions.
The new adaptation values are stored in the DME control unit after the engine is started for the first time.
Join BMWCCA
Old 12-14-2011, 08:58 PM   #12
e46Sushi
Info on my car:
Idle Air Control Valve did clear my P1542(Throttle Position Sensor Electrical.) but I bought the car with a new throttle body.
I am now running into a P1580(Throttle Mechanically Stuck) sometimes. I took a look at my throttle cable and has a lot of slack, looks like they didnt replace the cable at the same time as the throttle. I thightned the cable up but the slack returns after a lot of stop and go traffic. Again throwing the car into LIMP mode. I'm ordering a new throttle cable soon i'll let u know if that clears that issue to.
Old 02-04-2014, 07:38 PM   #13
malvstad
My Ride: 323I
Send a message via ICQ to malvstad
Hello, Did replacing throttle cable help?
malvstad is offline   Reply With Quote
Old 02-04-2014, 07:47 PM   #14
e46Sushi
Found the problem in my engine harness. Possibly from chaffing wire harness. And yes the replacing the cable in my car worked.
Old 04-11-2015, 01:46 AM   #15
SSpeedracer
My Ride: BMW
Where was the wire damaged? Near the TB connector?
SSpeedracer is offline   Reply With Quote
Old 04-12-2015, 08:50 AM   #16
e46Sushi
The problem was in the main wire loom from the dme to the junction block on the side of the engine under the intake manifold.
