Old 06-06-2011, 12:57 PM   #1
BillyBiggs05
My Ride: 330i
umnitza angel eyes
i recently purchased a angel eye kit from umnitza . i want to install them but i see the instructions are for always on .. i dont want them always on i want then to turn on when i click my light switch to the middle (before headlights turn on ) NEED HELP!
BillyBiggs05 is offline   Reply With Quote
Old 06-06-2011, 01:14 PM   #2
Shmo
My Ride: 2000 323i
Send a message via AIM to Shmo Send a message via MSN to Shmo Send a message via Yahoo to Shmo
Might get some better help in the Lighting Forum
You did pray to your BMW shrine first, asking the Great Roundel for guidance on parts' choices first, right?
Shmo is offline   Reply With Quote
Old 06-06-2011, 01:17 PM   #3
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
What do you mean by Middle position?
rizwan1377 is offline   Reply With Quote
Old 06-06-2011, 01:40 PM   #4
STORMER
My Ride: AA SC 98 M3
pretty sure he is referring to the light switch. when you turn it half way and the corners come on
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 06-06-2011, 01:45 PM   #5
johnewhite
My Ride: E46 M3
Parking lights. Instead of tapping the wire in the DME, tap the grey wire with the purple stripe in the LCM wiring bundle.
johnewhite is offline   Reply With Quote
Old 06-06-2011, 02:20 PM   #6
BillyBiggs05
My Ride: 330i
where is the LCM wiring bundle located?
Old 06-06-2011, 02:58 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I replied to your PM.
There are two wires:
Trigger wire - makes the angel eyes turn on/off with the interior lights
ECU wire- makes the angel eyes turn on when you turn the key to position 2 and when the car is on. Once you turn the key to position 2 they will stay on, has nothing to do with the lighting switch.
Old 06-06-2011, 03:02 PM   #8
BimmerE46 M3
My Ride: E46 M3
wire them to the DTL
BimmerE46 M3 is offline   Reply With Quote
Old 06-06-2011, 03:16 PM   #9
rizwan1377
Tapping with the corners: I don't think it's possible because the corners stay on with the headlights also. OR maybe its possible with the programming.
Old 06-06-2011, 03:22 PM   #10
BillyBiggs05
My Ride: 330i
i dont want them to always be on .i want them to be on when i turn the light switch one click ..
Old 06-06-2011, 03:30 PM   #11
ANREC330
My Ride: C6 Vette & M3
How about you tap into your fogs, that way you can turn them on/off whenever your heart desires
ANREC330 is offline   Reply With Quote
Old 06-06-2011, 03:42 PM   #12
johnewhite
My Ride: E46 M3
Look at pages 9 and 10 of the attached DIY. If the parking lights is not the position you want, then tap the wire that connects to the back of the switch at the position you want. If it is not readily apparent, then it's trial and error. LCM = Light Control Module or Light Switch.
File Type: pdf mycarre46prefacelift_instructions[1].pdf (1.22 MB, 67 views)
Old 06-07-2011, 01:07 PM   #13
BillyBiggs05
My Ride: 330i
And this wont give me a light on my dash right ?
Old 06-07-2011, 01:34 PM   #14
sakumaxp
My Ride: 02 M3 convertible
i got mine wired as my DRL. when i received my package of AEs, they didnt even make my bundle (little black box forgot the name sorry) right, we had to splice and solder all kinds of wires, but hey maybe your package has better luck!
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 06-07-2011, 03:14 PM   #15
rizwan1377
theres another way to turn them on; tap the trigger wire with the DRLs( day running lights).
