Old 06-07-2011, 09:34 AM   #1
XscoreX
My Ride: the dirt devil
Send a message via AIM to XscoreX
Cant change blinker with Xenon Upgrade Help!
ok I bought my car with a xenon and angel eyes upgrade already installed, after like 6 years or so I now have to change my right blinker. Problem is I have no idea how to get to the front blinker! theres ballasts and all kind of things in the way. I have a 2000 323ci. where do I start? I dont want to mess anything up
XscoreX is offline   Reply With Quote
Old 06-07-2011, 10:05 AM   #2
paraklas
My Ride: ESS TS2 320ci
There's either a philips screw there if you have OEM Xenon or a clip that holds the indicator on the headlight housing if you have halogens.
Old 06-07-2011, 10:20 AM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
^ Yup, either a screw you loosen to take the corner out or you have to push down and slide it out.
Old 06-07-2011, 10:20 AM   #4
XscoreX
thanks! I think theres a phillips there.
Old 06-07-2011, 10:21 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
Remember, don't screw it out completely, just enough for the corner to be loose and slide out.
Old 06-07-2011, 10:35 AM   #6
XscoreX
ok juat went and checked, there is a clip. I cant seem to get it out. i push down on it and nothing happens, it doesnt move, is this a clip at the top of the housing or is there something lower i need to press on? I pressed down and side to side but nothing. now im totally confused
Old 06-07-2011, 11:00 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
Push down and try to move the flathead back to towards the car so the corner gets pried out.
http://www.bimmian.com/elements/page...ht/DCL/DCL.pdf
Old 06-07-2011, 02:44 PM   #8
XscoreX
Thanks, I was pushing on the side guide tabs! I had to go in deeper and couldn't see it. I coulda sworn that this was different on my non xenon car. Oh well thanks guys
Sent from my DROID2 using Bimmer App
