Old 06-07-2011, 12:02 PM   #1
kimodo
My Ride: Sportwagon
cooling system overhaul, replace radiator as well?
I'm at 100,000 and getting ready to do cooling system overhaul. From your experiences should I replace the radiator since i'm going to have everything apart? I don't want to replace the radiator, if it is a quality part.. that isn't susceptible to premature failure. Replacing radiator @100k cheap insurance or pissing away $, Advice?
kimodo is offline   Reply With Quote
Old 06-07-2011, 12:06 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
No, radiator is not necessary unless it's leaking.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 06-07-2011, 12:57 PM   #3
rollingstone
My Ride: 330ci
I replaced my at 100K since I had everything torn apart. It's a simple job and good insurance for $100. Old radiator can start leaking at anytime.
rollingstone is offline   Reply With Quote
Old 06-07-2011, 01:29 PM   #4
Steven747
My Ride: 05 330ci
new oem radiator is 100 bucks?
Old 06-07-2011, 01:34 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
$140 at autohausaz.com
Old 06-07-2011, 03:28 PM   #6
Chris C
My Ride: 2001 325Ci
I replaced my radiator at 116K when I did my cooling system overhaul. I don't recall the cost off the top of my head. But I primarily did it for peace of mind. Plus I was still spending just about the same amount in parts it would have cost me to just have the thermostat replaced at the dealer. Good luck.
Chris C is offline   Reply With Quote
Old 06-07-2011, 03:38 PM   #7
josephmech
My Ride: 2001 325i sedan 5m
+1 bought for 150 behr not needed but good peace of mind
josephmech is offline   Reply With Quote
Old 06-07-2011, 03:40 PM   #8
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Mine started leaking at something like 190K miles and I replaced it maybe 2 months later after I decided it wasn't healing itself. It failed slowly on me...a leak between plastic and aluminum where they're crimped together. Not sure they don't explode, but don't recall hearing of one do that...that's what the ET is for!
YMMV, of course, but I did get ample warning and just needed to add maybe a few ounces/week until the rate of loss increased and I replaced it...as Jake said, for $140.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 06-07-2011, 03:40 PM   #9
miyata
My Ride: 2005 330 XI
I kept the old one.
miyata is offline   Reply With Quote
Old 06-07-2011, 04:11 PM   #10
antonmn
My Ride: 02 325Ci
I wouldn't replace it as a matter of maintenance. Maybe at 200k, but not 100k.
*signature*
antonmn is offline   Reply With Quote
Old 06-07-2011, 05:05 PM   #11
e46frvr
My Ride: 02 330i
Yeah no kidding. Thermostat housing + antifreeze = 500+ at dealer! (100 ish for part and 400+ for labor)
For all those recommending not to do radiator, does that mean radiator is not the weak link and overhaul refers mainly to water pump?
If so, why even replace pipes? Doesnt it make sense to just replace water pump and deal with stuff as it breaks? Just wondering...
e46frvr is offline   Reply With Quote
Old 06-07-2011, 05:09 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
Well think about it, the radiator is pretty much all metal so it can withstand the heat and coolant running through it. My radiator hoses at 90k all had bad bubbling on the inside of them. So it would make sense to change those rubber/plastic parts. Water pump has to be done because bearings can fail at any point and the expansion tank is known to blow up at any given second.
Old 06-07-2011, 05:23 PM   #13
BimmersGarage
My Ride: E46 330i
OP,
Overall, the radiator unit itself holds up pretty well under normal daily driving, even at 100K.
And, Especially in San Diego's beach weather.
Unless there is some damage ie: rocks or known leaks... you would be wasting money. Also, the time it takes to get to the radiator later on (especially after you done a cooling system refresh) will be a lot quicker (due to said experience) So, I would let it be. Our radiators can last up to 180+K, like Dmax stated.
Mine's currently at 117K in Texas Heat.
Just make sure you replace Everything else relating to the cooling system.
BimmersGarage is offline   Reply With Quote
Old 06-07-2011, 05:44 PM   #14
e46frvr
My Ride: 02 330i
Thanks, well said and good to know.
(I guess lay off the radiator on mine for a while)
