Old 06-07-2011, 12:21 PM   #1
unibagel
My Ride: 02 330i, 01 GLX
Angry Ok to run with 12v+ connected to Compressor?
Wife's 2002 330i has A/C problems. The compressor will only work if 12V+ is connected. Is it ok to rig up a switch to manually turn on compressor for a few days? She will be out of town for work and needs the A/C.
I've taken the car to two reputable shops and they can't figure out what the problem is. One shop refilled the refridgerant, still nothing. I bought a replacement A/C Head Unit thinking that would solve the issue, nope. Any ideas would be appreciated.
Thanks all!
Chris
unibagel is offline   Reply With Quote
Old 06-07-2011, 12:22 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
The best solution would be to have the car scanned with a BMW GT1 tool. Maybe you have an issue with the black box on the fan shroud which might be the cause.
Old 06-07-2011, 12:29 PM   #3
unibagel
Ok, but is there a way to jumper it for now? Who besides the dealer would have such a tool? I'm in Buffalo, NY area.
Thanks for your speedy reply!
Chris
Old 06-07-2011, 12:37 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
I would give the shops that specialize in European cars a call. Have you tried searching for "ac compressor not working" or something like that? I never had the problem so I can't be of any more help than what I am now. If you do know how to wire the switch for a few days go for it because it's going to be very bad for the next few days. :/
Old 06-07-2011, 01:21 PM   #5
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Problem with that is there is no monitoring of the high pressure side then. The AC compressor NEEDS to cyle to reduce pressures. If the High side pressure goes to high you will DAMAGE something!!!
I would NOT do it unless I had gauges hooked up to monitor pressures
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 06-07-2011, 01:29 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
Thank you. OP there you have it.
Old 06-07-2011, 03:14 PM   #7
unibagel
Wow, uber speedy responces. Thanks, I will not be doing that. I'll try picking up a low pressure switch and go from there...
Old 06-07-2011, 03:18 PM   #8
iansanderson
My Ride: 2001 330CiC
just get the IHKA scanned to see what the problem is. a reputable independent garage or the dealership can do this. throwing parts at the car is not a smart way to diagnose and will cost way more money than a diagnosis.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 06-07-2011, 05:14 PM   #9
BimmersGarage
My Ride: E46 330i
@unibagel
How did you diagnose or come to the conclusion that your A/C compressor only comes on with +12V?
BimmersGarage is offline   Reply With Quote
Old 06-07-2011, 06:42 PM   #10
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
Are you sure that the freon is not missing? I am not sure if E46 has the same system or different but most of the cars do have this switch: there is a low pressure cut-off switch which doesn't let the compressor turn on if the system has low/missing freon.
rizwan1377 is offline   Reply With Quote
Old 06-07-2011, 08:13 PM   #11
unibagel
I can see that it is not coming on and the shop ran a wire to it and it started.
yes The first shop filled it and the second shop verified there is indeed freon in there...
What else???
Originally Posted by BimmersGarage View Post
@unibagel
Old 06-07-2011, 09:16 PM   #12
rizwan1377
It is not not safe to hack it, it can damage your ac compressor, compressor clutch, hoses.etc It will damage the parts which are weak.
If you really want to do it, you need to hack the AC condensor fan also (if equipped).
Old 06-07-2011, 11:22 PM   #13
BimmersGarage
My Ride: E46 330i
OP,
I believe Rizwan1377 is correct on this matter. Forcing the compressor to activate when there is something wrong with the A/C system, would be a most costly venture.
If freon is low... I believe the system will not allow the compressor to engage.
Like Solidjake and jbeurotech have stated, better to take it into a BMW specialist/dealer to have the codes pulled or system checked properly.
