Old 06-07-2011, 01:16 PM   #1
Alex22
My Ride: BMW 330Ci Msport
Battery cover removing
Dear my friends,
I tried to replace my battery but I stucked at one step... To remove the black cover over the battery.. the two screw is ok... but to take it out? it's awful... Can you help me on this topic guys?
Here is the stucked cover... what to do with this? I also have a coupe..
Thanks in advance,
Alex
Alex22 is offline   Reply With Quote
Old 06-07-2011, 01:51 PM   #2
WheyArea
My Ride: '05 330ci ZHP
Unscrew the 2 screws then pull up and slide the back out from under the trunk wall trim.
WheyArea is offline   Reply With Quote
Old 06-07-2011, 02:06 PM   #3
Alex22
And I have to grab also the green fuel cap button?
Old 06-07-2011, 02:10 PM   #4
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
No, you take that button off the wire (it comes apart) only if you need to remove the fabric trim.
Stiggles is offline   Reply With Quote
Old 06-07-2011, 02:14 PM   #5
cvx5832
My Ride: 325Ci, 325Cic, C300
Dear my friends,
Thanks in advance,
Alex
Lift it enough to slide your hand inside, then push the black tray up from the back-most part of the tray, around where it meets the trim. Lift it towards the center, away from the positive pole.
Do that, and it will pop off.
cvx5832 is online now   Reply With Quote
Old 06-07-2011, 02:44 PM   #6
Alex22
Success Thanks guys
