Old 06-08-2011, 04:12 PM   #1
jetblackmaverick
My Ride: parting out...=(
Why does my car sound like its rolling on offroad tires?
Loudest road noise sound ever in my car. On a phone call had a girl say that it sounds like Im in a Nascar event. I just put my stock 17" wheels on and they are inflated to 36 psi. Im thinking wheel bearings...grr, opinions???
jetblackmaverick is offline   Reply With Quote
Old 06-08-2011, 04:22 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
Probably feathered tires, or the tires aren't balanced. My parents' Impreza has some seriously feathered tires and the car is loud as all get-out, all because it wasn't balanced/aligned properly to begin with.
Old 06-08-2011, 04:28 PM   #3
elanlyfestyle
My Ride: 03 325ci
yea its prob the bearing, both of mine were bad and the car was very loud inside
elanlyfestyle is offline   Reply With Quote
Old 06-08-2011, 04:33 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Bearing probably, can also be guibo, worn tires, alignment or the tires are just noisy to begin with.
Old 06-08-2011, 04:46 PM   #5
g6
My Ride: BMW
i personally like that? my first bmw had yokohama race tires and it was so loud. loved it.
g6 is offline   Reply With Quote
Old 06-08-2011, 04:48 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
Maybe you just like it rough?
Old 06-08-2011, 04:55 PM   #7
g6
My Ride: BMW
lol
hopefully not sounding too ghey but it def makes you just feel so much more connected to the road. i basically want the least amount of comfort possible when it comes to suspension/tires. that is why the e9xs feel so censored and soulless.. now that my brother has the e36, i have the e46 and my roommate has the e90, i see the trend they have followed after driving in all three often. and honestly it is a downward trend, at least in driving experience.
Old 06-08-2011, 05:00 PM   #8
jetblackmaverick
car was just aligned two days ago. Is there any way to visually inspect the guibo or is it just a type of part that you dont know until replacing? My stock wheels were never this loud before I swapped them out out for my iForged wheels.
Old 06-09-2011, 07:08 AM   #9
Jaundiced Outlook
My Ride: has a tailgate
You can see the guibo underneath the car pretty easily; it's this rubber hockey puck thing between the transmission and the driveshaft. Do a search in the DIY forum - there's a guibo DIY as I looked it up before. If the part starts cracking/shearing it should be obvious visually.
YMMV, but I lucked out and a similar road noise issue with my car turned out to be bad tires.
I had had a roaring road noise for a little while, and it got even worse when my wife and I were out of town visiting my folks. Had a helpful BMW dealer tech check it out (for free, surprisingly), because my wife was concerned we'd get stranded on our return home. I wasn't too keen on a wheel bearing possibly letting go on I-95, either.
The tech said it was feathered tires - not surprising since they were pretty worn (I had bought a used wheel/tire set). Had new tires installed last month - noise gone. Also did an alignment and replaced a bunch of worn suspension items, so hopefully feathering won't develop again.
Jaundiced Outlook is offline   Reply With Quote
Old 06-11-2011, 06:59 PM   #10
JerzyBoy973
My Ride: 01 330ci
How would one confirm that a wheel bearing is bad? Am I looking for some sort of shimmy in the hub once I have the wheel off?
JerzyBoy973 is offline   Reply With Quote
Old 06-11-2011, 07:00 PM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Jack up the car and with the wheel still bolted on grab the wheel at the top and bottom and see if there is play.
Old 06-11-2011, 07:09 PM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Hmmm? If you rub your hands along your tread and it feels like fish scales, it could be shocks too.
Also 36 psi is probably fine for the rear, but sounds high in the front, unless you have real low profile tires. Start with using door jamb pressure and dial in slightly from there. If you have a normal sized tire, I think that front pressure is way too much, would induce not only more oversteer than you want, but wear the tires much quicker than normal.
Check the door jamb.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 06-11-2011, 07:09 PM   #13
JerzyBoy973
My Ride: 01 330ci
Thank you sir!
Should I consider bearings like tires and replace left and right together?
Old 06-11-2011, 07:14 PM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
Just the one bad one.
Old 06-11-2011, 07:20 PM   #15
JerzyBoy973
My Ride: 01 330ci
awsome thx
Old 06-12-2011, 03:37 AM   #16
jetblackmaverick
Solidjake, that test sounds like how I checked and found that my LcaB was going to hell, didnt know it was good at identifying bad bearings.
Old 07-09-2012, 05:09 PM   #17
Bluebarry
My Ride: E46 M3
Probably a dumb question. What is the LcaB?
Bluebarry is offline   Reply With Quote
Old 07-09-2012, 05:27 PM   #18
JDez
My Ride: 2001 330i
Lower Control Arm Bushing
Sent from my myTouch_4G_Slide using Bimmer App
JDez is offline   Reply With Quote
Old 07-09-2012, 05:48 PM   #19
mbnz230
My Ride: 2004 BMW 325ci
36 is definitely high for the front, my stock psi for front on the 17's is 30 and i do 32 for the 18's. it rides nice and quiet. i tried to put like 35 for the front cause i did search on here and everyone recommends high psi. it just make the car ride stiff.
are those new tires you just put on? what condition are your tires?
mbnz230 is offline   Reply With Quote
Old 07-09-2012, 05:57 PM   #20
Toadman
My Ride: 325ci and X3
Wheel noise
I just fixed a rear right wheel bearing on my 2002 E46 vert. I swore it was road noise from my tires but I was wrong. The car only has 66,000 miles on it. I bought a second car with the same noise and it ended up being cupped tires. The tires needed to be replaced. The tires were easy to troubleshoot by running your hand over the outside tread and verifying they are smooth, not chopped. My point is they sound very much alike. Also just because your car has low miles doesn't mean your bearings aren't the problem. Thanks Ohio for all the pot holed streets.
Toadman is offline   Reply With Quote
