Old 06-09-2011, 06:46 AM   #1
TR4G-
My Ride: '01 325xi, '90 325iC
Lost engine block drain plug!
Hah so I finally got that sucker off to drain the coolant from the engine block Into a bucket, and when I looked into the bucket afterwards only the crush washer was there!
I think the pressure of the coolant propelled my drain plug into the under body of the war somewhere! I couldn't it find it on the ground anywhere. I searched but couldnt find anything. I remember there was post similar to this where the person located where it was lodged/resting in their car. Does anyone remember or know?
Also, can I reuse the crush washer? And also where are there o rings in the cooling system? I'm replacing my radiator and lower radiator hose. Do I have to worry about o rings?
Thanks!
TR4G- is offline   Reply With Quote
Old 06-10-2011, 09:22 PM   #2
jmay87
jmay87's Avatar
My Ride: e36,e46,e90
My drain plug has fallen and landed on top of the motor mount arm. You might get away with reusing the crush washer but they are like $0.20 so you might as well replace it. The o-rings are all part of the hoses so you can really only replace them if you replace the hoses.
--1995 E36 M3--2001 E46 325i--2008 E90 335i--
jmay87 is offline   Reply With Quote
Old 06-10-2011, 09:41 PM   #3
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
check your motor mount or the....top of your control arm
Old 06-11-2011, 11:25 AM   #4
paraklas
My Ride: ESS TS2 320ci
It's a crush washer. Meant to be replaced not reused. It works as a gasket to prevent fluid leaks so I'd replace it with a new one.
