Thread Tools Search this Thread Rating: Thread Rating: 75 votes, 4.77 average. Display Modes
Old 06-28-2012, 04:22 PM   #201
Vigilante
My Ride: 320i - 2.2 L - 170hp
Send a message via MSN to Vigilante
well, I did the swap and I left the clips on. All works well so far.
320i Executive Sedan | E46_AV11 | ZF5HP19 S-t | M54B22 | 170hp 210Nm | 09/2000 | 171k | 32.9 MPG
Maintenance
Re-surfaced CH | VC+VCG | CAM/VANOS timing | IMG | NGK-i | BAT+ALT | O2's | GM5 | WP WPP | PSP | DISA | TB ICV MAF | CCV | CAI | OFHG | FP | FF | A/C | FSU | AUC | WSS | BL BD BP | Mango | JFOJ | SB TP IP | springs | Shocks | tires | ASC+ | alignment | E.Flush | Castrol SAF-XJ 75W140 | ZF LGF5 ATF Flush | FCA+FCAB | Struts
Vigilante is offline   Reply With Quote
Old 06-29-2012, 10:09 AM   #202
Vigilante
I like it, I like it and I like it The car is so quiet at Idle, less vibrations too. I noticed my RPM at highway cruising speed (with cruise control, 75mph) went up a notch from 2300 RPM to 2400 RPM, the cars warms up quite fast now, before I even reach the Highway (2,5 miles) and psychologically the engine feels kind of lighter/smoother All I can add to this all is Solidjake FTW!! I'm gonna spam this swap all over the Dutch Bimmer boards
Maintenance
Old 06-29-2012, 06:55 PM   #203
fire730
My Ride: 01 325iT - 04 Burb
The clips are there to balance the fan. So I'm glad you left them on.
fire730 is offline   Reply With Quote
Old 06-29-2012, 07:09 PM   #204
325guy
Banned User
My Ride: 2003 325i stick
Te electric fan is far superior to the mechanical fan because of the damaging vibrations to the pulleys belts and cooling system
325guy is offline   Reply With Quote
Old 06-29-2012, 08:23 PM   #205
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Awesome
enjoy!!
Old 06-29-2012, 11:35 PM   #206
Vigilante
Ah great, thanks. Now my mind is fully at peace with it
Maintenance
Old 07-03-2012, 08:03 AM   #207
Sweetness
My Ride: '01 325i
Tip: If you go to BMAParts.com and type in the part number, the product will say it is not currently available, however, if you PM Yves Bright on the website, he can get an OE Fan for $182!!!
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 07-04-2012, 08:52 AM   #208
michaltt
My Ride: bmw e46 325i
i have question. What if my new electric fan fails during hot day in city ? You cant notice that becuase its relatively quiet. And i dont want to see temp needle in red light.
So there is no warning before you end up in smoke and exploded cooling system.
Mechanical fan is making some drag onto belts and other things but its more reliable beucase it fails rarely and if it fails, you can hear it that fan is not making truck noise. And most of the time when mech fan fail, its always engaged
= its cooling your radiator even when its broken.
michaltt is offline   Reply With Quote
Old 07-04-2012, 09:14 AM   #209
Sansho
My Ride: 2001 325i
You'll see the temperature gauge moving into the red.
If it goes that far, you're not paying attention.
The mechanical fan can fail by locking and spinning all the time, which makes more noise but doesn't hurt anything. The mechanical fan can also fail by losing it's blades and sending them into the radiator, and has also been known to dent the hood. If you scan these discussions, you'll find a number of failures like that.
If you want to drive and don't pay attention to the gauges, you're correct, you should stick with the manual and electric fan combination.
Sansho is offline   Reply With Quote
Old 07-04-2012, 09:32 AM   #210
michaltt
yes thats true but who wants to drive with eyes sticked on temp needle ?
And you know that with some passengers in car, music etc you are not able to watch temp needle always.
Other thing is that temp needle will go into red in few seconds and that few seconds can kill your engine because few seconds in red light = thousand of dollares.
I know what im saying. I had one engine swapped. And why ? I was trying to park my car between 2 cars when my viscous clutch failed. I had my head turned on rear glass when trying to park correctly and when i turned my head to front, i saw white steam.
Electric fan can fail anytime because its fact. And imagine that you are driving in city with 38C outside, talkin with friend and you didnt notice needle in red.
All you wrote about mechanical fan is true but fact that its more reliable in term of cooling is proven by bmw mechanics. I want to do swap to electrical too but im just thikning and asking myself what if ...
I know that mechanical fan can damage some other things but mechanical fan will fail when clutch is engaged and you spin your engine to 6500rpm. And when cluthc fail, you can hear it. When you hear it = its time to replace clutch.
Old 07-04-2012, 10:09 AM   #211
michaltt
And one thing should be useful : sound warning when temp needle goes away from 12o`clock position, constant beeping when temp needle touches line after 12oclock position etc. Something like beeping or long beep which depends on temperature.
I think that with this feature, most of engines which were blown should be still alive.
I`ll speak with my friend about it. If its possible to install sensor into engine bay and make warning system based on cooling temp.
Old 07-04-2012, 10:47 AM   #212
michaltt
.m
Old 07-05-2012, 09:10 PM   #213
Solidjake
Zero. Leaks.
Solidjake's Avatar
Might be possible to do that. I hope someone does come up with something like that.
Old 07-06-2012, 06:04 AM   #214
yetieater
My Ride: '03 330i
Someone has developed a system that monitors the coolant temperatures and alerts the driver of overheating. It's pretty neat stuff to read about. The big surprise is the large window of temperatures in which the needle keeps its 12 o'clock position as programmed..
Anyways, here's a link to the Coolant Snitch
http://zhpregistry.net/Tech/CoolantSnitch.aspx
bulletproof one piece at a time
full listing of BMW Performance parts for the E46
yetieater is offline   Reply With Quote
Old 07-10-2012, 07:06 PM   #215
Sweetness
My Ride: '01 325i
Looking forward to someone who can reply to MichalTT's statements. Maybe even E46Mango because we have been tag teaming the boards today! But yes, I was almost about to order this until reading Sansho's reply...made me think that these electric fans CAN fail, and what about the people who said the fan was running up to 10 minutes after the car was shut off?
2001 325i ZCW, ZPP
Old 07-10-2012, 07:57 PM   #216
Sansho
My Ride: 2001 325i
...and what about the people who said the fan was running up to 10 minutes after the car was shut off?
It is normal logic for the computer to run the fan for up to 10 minutes after the engine is shut off, based on the computer calculated catalytic temperature.
Old 07-10-2012, 08:20 PM   #217
wildcat293
My Ride: 325xi
Don't forget that even if you have the mechanical fan you still have the electric aux fan that can fail. You will overheat just as bad and cause just as much damage if you don't notice the temp gauge going up. Judging by the awful sound it makes when its on I bet its lower quality/lower lifetime than the "full" electric fan too.
wildcat293 is offline   Reply With Quote
Old 07-12-2012, 07:40 PM   #218
Sweetness
My Ride: '01 325i
2001 325i ZCW, ZPP
Old 07-12-2012, 10:18 PM   #219
trive2
My Ride: 1989 BMW 535i
I'd be curious to compare the actual failure rates between the two parts.
trive2 is offline   Reply With Quote
Old 07-13-2012, 12:52 AM   #220
J1Productions
My Ride: 2000 323i
Thanks for this diy solid. I think I'm going to tackle this one. What would you rate the difficulty level at? I believe I have all these tools, not sure what fan clutch tools are though.
J1Productions is offline   Reply With Quote
aux, auxiliary, behr, bosch, bumper, clutch, damage, electric, engine, explode, fan, hood, manual, mechanical, mount, mounts, removal, swap
